/ Harbor Freight Tools that don't suck #14,331
Anyone have experience with this?
Have 2 of them, 1 for work & 1 for the garage... It's not a everyday tool but they are really handy to have. Sometimes a little awkward to use, a third hand can be useful at times depending on the location of the crimp you are making; no issue using them at the bench.
We would sometimes have the dies drop out because of the position we needed to get the tool in & they just slide in to the hole on the tool. We resolved it by using a little dab of Sil-Glyde lubricating compound in the holes on the tool. It is sticky enough to hold the dies in & works great (& doesn't melt & make a mess when you leave the tool case in the truck in the summer).
Other than that it works good with a good selection of dies, I would guess on of my sets is 8+ yrs old. There are similar & less expensive units on Amazon & eBay.
/ Harbor Freight Tools that don't suck #14,332
I have Goplus 16 Ton Hydraulic Wire Crimper Battery Cable Lug Terminal Crimping Tool w/ 11 Dies - - Amazon.com which is identicle tone HF use to sell. The one they have now has a 1 sided end on it which is probably weaker but more convenient.
Mine has been fiddly but entirely adequate for a cheap Chinese tool. Maybe 200 crimps on it over the past few years. A better one would be better, but likely not worth the price even for an advanced home user. Would buy again.
/ Harbor Freight Tools that don't suck #14,333
Yes, I have one, and it works great. You just have to learn which size dies to use with which size wire/connector.
/ Harbor Freight Tools that don't suck #14,335
I have only used the hand power crimpers but what I do like about them is the dies are held in place and can be rotated with a push of a pin on each jaw.
On needing three hands... that is my biggest problem. Extremely hard to keep the terminal snug on to the wire while crimping with two hands.
/ Harbor Freight Tools that don't suck #14,336
I don't have one of those crimpers but I do have multiple ones that are much higher quality. I can't see how it would be useful for crimping small diameter wires. It would be like using a sledge hammer to drive a nail. For larger wires I think it would be useful. I have a very similar tool for flaring brake lines. It's just not very fast.
If you are looking for something to do smaller wires (up to 10 gauge) then Tyco makes a great one. It has a spring loaded arm that holds the connector so you just need to hold the crimper in one hand and the wire in the other. But they are expensive. You probably can find a used one on ebay though. The plastic on the handles break on the older ones but they are still fully functional.
59824-1 | eBay
/ Harbor Freight Tools that don't suck #14,337
Yeah, humans should have been born with three or four hands.
I usually clamp the fixed handle in the vise with soft jaws to use it.
/ Harbor Freight Tools that don't suck #14,338
As usual, Rod was way ahead of you:
/ Harbor Freight Tools that don't suck #14,340
Skikir, welcome to TBN;
Here's HF's version
I have one, could use a couple improvements but works OK once you figure out which dies to use for what... Steve
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
2008 BOBCAT T320 SKID STEER (A62129)
2008 BOBCAT T320...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2015 John Deere 6105E (A60462)
2015 John Deere...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
