Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #14,341
Looks like I'm ordering a 44" tool chest this weekend with the 10% off because they're out of stock with most colors. White? No thanks
   / Harbor Freight Tools that don't suck #14,342
The boxes are great, I'm getting used to the latches on my 56" box, the 44" I have in the garage is nice... it's odd going from the latches on the main top and bottom to no latches on the side cabinets but I'll get used to it, especially after I finalize what's in what drawer...
This week I picked up the 20 gallon oil drain thing I ordered a couple weeks ago when it was on sale. My only complaint is the male pipe threads for the upright are over cut, both on the tank outlet and the chromed pipe for the funnel, both just threaded on until the threads bottomed out... so ~5 wraps of tape it is... otherwise it's a neat setup, now I just need to get the lift installed so I can use it as intended :).
I also picked up a Bauer leaf blower, it's not bad but not as refined as I expected, no trigger just a thumb wheel with 0, 1 and 2... The Lynxx is nicer, I'm sure the new brand is nice too, even the "workshop blower" from Bauer has a variable speed trigger and 3 speeds... Whatever, for $42 open box I can't complain, and for whatever reason in the box was a 3/8" flex ratchet head (no handle) and a little baggie of pop rivets... you never really know with open box returns :)
   / Harbor Freight Tools that don't suck #14,344
Ratchets? Power Ratchets? Do we REALLY need power ratchets? $100 power ratchets?
In certain situations... YES!
I just bought a tractor, and the same thing could be said about it.
   / Harbor Freight Tools that don't suck #14,346
Just bought the 12k badlands winch with the 90 day warranty also spent another $90 for the extended warranty.
Wondering if i wasted money- for something that I won't need.
Anyone bought the 12k winch and have problems early on?
   / Harbor Freight Tools that don't suck #14,347
Only used mine a couple times in a couple years. Holding up fine for loading a few cars & logs on the trailer. It lost the fight but didn't break when I started a game of tug-of-war between 8k lbs of tractor & the trailer testing out my welds for the receiver I put on the front of the trailer. The HF winch cradle didn't fit well or hold up, but one off Amazon, my welds & the winch are still going strong.
   / Harbor Freight Tools that don't suck #14,348
Their table saws are cheesy and not accurate. Spoiled by Delta contractors saw, not very portable, however. The jackhammer is an exact copy of an older premium machine and works very well. Cement mixer ok as well. However had to assemble 2 to get a working one. 1st one failed to operate. The plate compactor also works very well. Not worth renting one if you have a patio or walkway to do, just buy theirs. All of their tools are Chinese copies of tools made elsewhere. The best ones are from factories in China that make components for well known mfrs. Sometimes if you print out the owners manuals, they have actually, accidentally left the other mfr name in the manual.
   / Harbor Freight Tools that don't suck #14,349
Your uses are very similar to what i will be doing, starting with moving several non running vehicles from another property. The tilt trailer will not allow me to open the doors once driven or pulled up on the bed.
Looking forward to No more contorting to crawl out of the drivers window or having to "come along" a a truck up an inclined ramp.
Will also be cutting some standing dead trees from another property for firewood which has some really tight areas that a winch will definitely be helpful getting the logs to where they can be grabbed with a grapple.
I also bought that receiver hitch mount from HF and it does seem "light duty" compared to the winch, it is meant to contain. Needed the versatility to mount the winch to any rig/tractor I have with a receiver hitch. Since wife was headed to town and i was cutting steel to make a mount for the receiver there was no ability to check out the mount first
She also made the warranty choice for me. Said they told her it was the "idiot proof" warranty- Now I know why she bought it for me.
ps. Sounds like I should have had her buy the extra warranty for the winch cradle mount instead of the actual winch. Then again if it is weak in general it does not look like there is any easy way to beef the entire structure up enough.
What failed on the HF cradle? and what amazon unit did you choose to replace it?
Thanks for the info /experience it is appreciated.
   / Harbor Freight Tools that don't suck #14,350
Amazon.com: ORCISH Bumper Hitch Receiver Winch Mount Mounting Plate - 15000 Lb Capacity …: Home Improvement the carry arms/handles failed because of some bad rigging. It wasn't rated for 12k, only 9k if I recall, so wasn't to surprising. The mounting plate was very thin & light for the purpose. I like the adjustable handles on the Amazon one, makes for a more compact unit.
Photos of when the winch finally stalled out. Pulled fine on the grass/sand & the start of the trailer. But better traction & the tilted deck let the brakes beat the winch.
I think there are wireless remotes for em, but I only have the stock wired one. I have a wireless for the power tilting deck. It's super nice for loading & unloading the tractor. Key fob just hangs in the cab.
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2829 (A58376)
2829 (A58376)
Rhino DB150 (A57148)
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
LOT: (10) Fuel Cans (A59076)
LOT: (10) Fuel...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
