Do fires extinguishers need to be shaken to prevent settling?
/ Do fires extinguishers need to be shaken to prevent settling? #41
There are two (that I'm aware of) situations where you don't want to use a water extinguisher - electrical fires and flammable liquids fires.
That thar be why the soap was added . It makes the suds that float on top of the gasoline . As for
Electrical , I wouldn’t hesitate to hit 600V with a AFFF 2-1/2 gallon from 10 feet away . The foam is a lousy conductor .
/ Do fires extinguishers need to be shaken to prevent settling? #42
Four.
Three.
Everybody forgets about Class D - Metals. Not much of a problem in most homes, but it can be in a shop that does metal working and has aluminum or other metal scraps and dust.
Add Class K if you deal with kitchens and cooking oils.
. Magnesium and Zirconium will also burn.
/ Do fires extinguishers need to be shaken to prevent settling? #44
Is a cupful necessary? I put a big squirt, maybe <2 oz. in mine. I don't know what the Goldilocks amount is. Should I be trying to make lots of foam or is soft water and a little foam good enough?
Some is good and more is better. Soap is cheap .
/ Do fires extinguishers need to be shaken to prevent settling? #46
I have always made a habit of turning ours upside down every fall and giving the bottom a few smacks with a rubber mallet to be sure the dry chemical powder inside the devices does not get caked.
Ditto. I smack the bottom and sides with a rubber mallet, and give it a good shake to fluff the dry chemical.
Generally, the ones with metal valves can be serviced, but it's cheaper to buy a new one. The plastic valve units are disposable.
/ Do fires extinguishers need to be shaken to prevent settling? #47
Amerex link above says don't do that, see #30. Calls it a Myth if one takes time to read it.
People get set in their ways..lol
/ Do fires extinguishers need to be shaken to prevent settling? #48
I did school maintenance for 30 years and making sure the extinguisher powder was loose was part of our monthly visual inspection. We also had to remove the hose to make sure it was clear and check the gauge for proper pressure. If the extinguisher was powered by a CO2 cartridge, it had to be removed and weighed for the proper charge.
Having eyes and hands on your extinguishers can't hurt.
/ Do fires extinguishers need to be shaken to prevent settling? #49
Prior to WWII it was correct to shake, it seems somebody forgot to tell us to stop..lol
Best advice I read is right here-
" Ask anyone who advocates shaking to produce a manufacturer’s document that recommends it.”
More on it here..
/ Do fires extinguishers need to be shaken to prevent settling? #50
New Holland 650 Hay Baler (A53317)
New Holland 650...
Takeuchi TB290 (A60462)
Takeuchi TB290...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
John Deere Gator (A53317)
John Deere Gator...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
