JD 820 switch
/ JD 820 switch #1
Mtbassman
1972 John Deere 820
Hi, I've got a '72 JD 820 and bought the recommended replacement switch #al19890. Does anybody have a diagram for hooking this switch up? I can't figure out which wire goes where. It didn't come with any directions. Any help would be appreciated! Thanks
/ JD 820 switch #2
I have wiring diagram for later model 3 cylinder engine 2040 but I think it's different from 820 because diesel fuel is controlled at IP by electricity on 820 & manual cable on 2040.
Bat wire is red from circuit breaker,neutral start switch is black,alt light is red.
/ JD 820 switch #3
There should be 4 wires to terminal 15. One should be a black wire that goes to the switch for thermostart. One should be a black wire going to ground the alternator light and air filter indicator light. One should be a black wire to start safety switch. Other one should be a black wire going to fuse 2 in fuse box. Terminal 56a should have a white wire to fuse #8 in fuse box. Terminal 56b should have a yellow wire that goes to fuse 7 in fuse box. Terminal 58 should have a gray wire going to fuse 5 in fuse box. Terminal 30 should have a red wire going to fuse 1 in fuse box.
/ JD 820 switch
The original switch pushes in to start the glow plugs and push button below to start. Only turns for the different light functions. Looks like a resistor on the back of it also. Never saw that before on a switch. I'll post a pic when I take it out again. Thanks for the replies!
/ JD 820 switch #5
Yes sir I was surprised many yrs ago of needing to push key into switch to start a NEW JD 820 utility tractor.
FYI this model JD tractor has "no glow plugs".
/ JD 820 switch #6
The light switch on my 2030 has a resistor on the back (coil of resistance wire) I think it's to dim the "headlights" on the fenders (forward facing lights)
/ JD 820 switch #7
Did you ever get it wired in?
/ JD 820 switch #8
Welcome to this forum
I couldn't locate a 820 utility tractor JD tech manual. My next choice would be the next newer model 830 utility tractor TM
Wooden Plant Holder (A64557)
Wooden Plant...
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64556)
Interstate 20ft...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
Beverage Truck Body (A64556)
Beverage Truck...
