Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 25,746
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Keep in mind a PTO mulcher on a tracked unit is hydraulically powered. It will "bypass" hydraulic fluid through a relief valve when it encounters more than it can handle, greatly reducing shock loads. Also, a tracked skiddy with a mulcher can raise up 8' and mulch DOWN on stubborn and tall stuff. Also gets excellent traction and is maneuverable-turns on a dime. These features are greatly superior to a tractor 3 point mount and cannot be overemphasized. (I had considered a Brown Tree Cutter, but decided against it)
A rear tractor mounted mulcher is PTO driven (I guess there are pump versions available, but I'm assuming you are looking at PTO). Even though it will likely have a slip clutch, it will place tremendous shock loads on your PTO when you hit an "immovable object" or too thick a tree and wear your PTO out faster than say, field mowing. That's an expensive repair. Also, you are very limited in how much you can raise a 3 point mounted brush mower.
I just did 50 hours/20 acres this past week in a tracked skiddy with a mulcher and the shock loads were such that the mulched hydraulic motor was bypassing often, then recovering.
The raising of the loader feature was invaluable. It would have taken me twice as long without being able to raise the mulcher.
Your best bet is a tracked mulcher for the tough stuff, then use your tractor with an extra heavy duty bush hog to clean up and pulverize the left over shards of wood and cleaning up between trees.
Thats what I have done and it works out great. Cutting down trees one-2 at a time and chipping them is a long drawn out back breaking process compared to pushing them over and grinding them up while laying on the ground. The mulcher will easily grind up a 8" stump almost as good as a stump grinder. Good enough for woodlands, maybe not quite perfect enough for a front yard.
BTW, I rented a like new CAT hi flow tracked skiddy with mulcher for $2300 for 50 hours/7 days.
