Adding teeth to a FEL
/ Adding teeth to a FEL #1
Thing
Yanmar YM 226D 4x4
Hey guys. Just picked up a small ym226D I'm guessing mid to late 80's. I want to start some food plots on 95 acres I own. It looks to be abandoned pasture, some young growth but alot of open weedy areas. Has anyone had any success using a FEL with teeth attached to prep the ground for seeding. I realize this tractor isn't a bulldozer but I'm curious if anyone has had any success using the bucket with teeth for this application ? Thanks
/ Adding teeth to a FEL #2
Not the proper tool,get a inexpensive "middle buster/a.ka. potato plow" after brush-hogging.
/ Adding teeth to a FEL #4
Exactly... a tiller, after slashing the area, will get the job done right.
A FEL isn't designed to dig.
I disagree.
I added a DIY toothbar on my Mitsubishi CUT and it now thinks it is an excavator.
Full buckets every time in rock infested soil and with bucket vertical it is a great root back drag.
I installed 7 'teeth' on my 4 ft bucket and that made it a whole new tool.
That was almost 10 years ago and never any issues or damage.
/ Adding teeth to a FEL #5
plowing 95 acres using a bucket with teeth, would have to have a huge amount of patience.
Tiller + brush hog would make this much easier.
/ Adding teeth to a FEL #6
I seriously doubt he's planning on making a 95 acre "food plot"... but you are correct, that would not be a fun chore with only a toothed bucket - might be better off with a pick and shovel!
/ Adding teeth to a FEL #7
IF you got rocks---tiller not good idea! use a regular disk! Toothbar on bucket will work---just slow. I use a bolt on one on my nh 781 all the time and have dug out some nasty stuff with it---just dont go hog wild with them and they are fine.--and yes loaders are used for digging in dirt!
(4) ROW FIELD CULTIVATOR (A62130)
(4) ROW FIELD...
1762 (A58375)
1762 (A58375)
2017 International HX620 Quint Dump (A62613)
2017 International...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Bad Boy Z-Turn Lawn Mower (A64047)
Bad Boy Z-Turn...
2020 ASV RT120 Forestry Skid Steer (A61166)
2020 ASV RT120...
