BX filter relocation
/ BX filter relocation #1
sandyc
Steep Falls, Maine
BX 2380
Just bought and installed the Botaproducts filter kit. Excellent execution and quality. Gave me the gumption to take care of this problem. The Kubota filter they supply is for the L series tractor which has a positive on/off valve and is made of metal. The bowl is translucent so you can see if there are contaminants or water. The filter mount will outlive anything I can throw at it!
/ BX filter relocation #2
If I had a BX, I would also do this modification.
I did a similar job on (2) ZD mowers which have a similar filter setup, although I used a large spin on type 2 micron filter. I still have another ZD and L4060 to possibly modify also.
How about a picture?
Trying to upload a pic
/ BX filter relocation #4
I’ve had mine sitting here since fall. Haven’t had time. I endured gelling this winter, which I believe to be an issue with the first factory filter sitting right at the hydro fan getting a steady stream of ice cold air being drawn to the tranny. I will get my new filter installed before the mower goes on. Then I’ll order a few spare filters for the shelf. I’m still considering installing a set of quick disconnects to change the factory filter on the side of the block.
On a side note, I just ordered yesterday the replacement steering boots from the same guy. I still may sleeve the replaced boots on the tie rods with bicycle inner tubes and zip ties just to keep them protected.
I didn’t have any gelling yet, we’ve had a warmer than normal winter, but decided to change things out on my time not the randomness of the weather. Lying on cardboard on a cement floor at my age is bad enough and can’t imagine trying to change filters in the snow outside.
/ BX filter relocation #6
I installed a similar system years ago that I put together myself and is pictured on TBN somewhere. I’m still using the original filter element and it’s nice to have a clear bowl beneath the filter to check for contaminants. I still have the filter in the engine compartment and have had zero problems.
/ BX filter relocation #7
I’m not sure why Kubota has two filters on the BX other than covering themselves due to a poorly designed filter system that utilizes poor filters. After have a small engine business for 9 years when I was young, the Kubota filters aren’t much better than those used on a lawnmower or snowmobile. That said, I’m sure the secondary filter should remain very clean since the primary filter should snag 99% of the debris. When I install the new L-type filter and bowl, I’ll replace the secondary, and probably make it habit to do the secondary every time I change the primary. For the $4.95, it’s cheap insurance in my book.
/ BX filter relocation #8
My Cummins has two fuel filters. I'm no mechanic but everybody I've talked to says it was a giant step forward for diesels.
/ BX filter relocation #9
Is it pretty stout? I could see it getting hit, there.
/ BX filter relocation #10
I've had mine for over three years. Best mod I ever made to the tractor. Very stout, haven't hit it with anything....yet. It's a relief knowing I don't have to change the OEM filter any more, and this one is much bigger and of course highly visible.
/ BX filter relocation #12
That is a real sorry place to mount it.
Not really. Very similar to other tractors. Guess it’s like anything... gotta pay attention. On the BX, it’s not much worse than the stupid HST fan. Be careful.
Smokeydog just posted a picture of his grill guard on this forum, and I noticed his filters on his L-Series aren’t located much better from the factory. The B’s aren’t much better.
/ BX filter relocation #13
I'd be grateful for a better suggestion. I looked the tractor over pretty carefully and found this to be the best compromise between accessibility and protection. Mine (Racor) has been in place for more than a few years with no problem, and it's easy to check and replace the bowl/filter
/ BX filter relocation #14
I would have to disagree. I've had mine for three years and haven't paid it any attention at all when using the tractor and have had no problems. Not only that, the location makes it easy to do a quick visual on the filter. Don't forget that these are small tractors and that really limits the location possibilities.
/ BX filter relocation #15
I got my fuel filter kit from Mike (bxbotaproducts) almost 4yrs ago. Zero problems or issues since installed on our BX23s. Best kit on the market as far as i`m concerned. Mike`s attention to detail making these kits is spot on. It took no time at all installing it. Its straight up foreword, detailed instructions. Its a WIN/WIN. To bad Kubota couldn`t have done this from the factory. Its not like they dont have the parts already sitting there. I did leave the small factory filter up front. I dont see any reason to change that out to something else, unless it becomes an issue at some point. I change ALL my fuel filters once a year. Just good insurance.
Now, the very first time i changed the large fuel filter in its first year of owning it, there was a bunch of water in the bottom of the cup. Tractor never skipped a beat either, but i`m sure happy to know to look for that from now on. Thankfully by installing Mike`s filter kit, otherwise i would have never known there was that much water in the fuel system. I must have gotten some bad fuel along the way. Now i watch the cup alot more often. If this had been the OEM tiny filters, that water would have froze and killed the tractor during wintertime.
Buy once, cry once. Anyone on the fence thinking about it, buy the kit, it will save you from painful headaches later on down the road. My first year, it saved me from a headache.
And the beauty of this kit, you can go to kubota and get the correct filter for it. (L series filter) I bought a few spares just incase.
/ BX filter relocation #16
After 4yrs with this kit on our BX23s, i`m still lovin mine! Zero problems or issues. Mike sells a GREAT kit, it works.
Towmotor/Lull/JLG/Barber-Greene Manuals (A63117)
Towmotor/Lull/JLG/B...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
2005 Nissan Frontier Crew Cab Pickup Truck (A61573)
2005 Nissan...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
