Hydraulic flow rate loss for 3rd function
/ Hydraulic flow rate loss for 3rd function #1
slingha
Member
Chester
Bobcat
My tractor is rated at 11.34gpm at the pump. Im sure there is some loss through friction and whatnot. Does anyone have any idea if there's a rule of thumb as to how many gpm is available at the 3rd function valve? I do have a HST. The attachment I am looking at requires 7gpm and it is loader mounted. Thank you
/ Hydraulic flow rate loss for 3rd function #2
Usually HST is a different pump than the implement pump. Also some tractors have dual (two pumps stacked, or end to end) pumps, one for implements and one for Power Steering. If your steering is not included in the 11.34gpm, I think you will be fine.
/ Hydraulic flow rate loss for 3rd function #3
Is that 11 gpm the implement/3pt system alone or is it "combined" flow where they add the steering circuit even though there's no way to use them together?
The rule of thumb for minimal pressure drop would have your 3rd function valve sized for 125% of system flow or more. If your implement system is 11 gpm and you size the valve etc properly you will have more than 7 at the implement. If it's a motor make sure the valve is rated for continuous operation and also consider a "motor spool" valve where the work ports are open when in neutral. With the usual style valve they are closed so cylinders remain in place, but that means that when you put the valve to the off position the motor comes to a sudden stop which could be hard on it or the stuff it's turning.
/ Hydraulic flow rate loss for 3rd function #4
My Kioti CK4010 has 11.7 GPM hydraulic pump flow, and 2.3 GPM is shared to the power steering. That leaves 9.4 GPM for attachment and implement hydraulics. The HST and 3pt hydraulics is run as a different system, and has its own dedicated hydraulic filter.
/ Hydraulic flow rate loss for 3rd function #5
You're right with that free flow for motors.
If there is an existing system already, there is an easy fix to that problem. Put a T in every line of the attachment. Connect the open ends with a check valve. We've manipulated the springs just enough to hold the internal ball against it's seat. If the implement gets started and pressure builds up in the line, the ball will be even pressed harder against the seat and stays closed.
If the circuit is abruptly closed, the momentum of the spinning implement (and the motor) can suck that weak check valve open and stop the rotation more gently.
/ Hydraulic flow rate loss for 3rd function #6
Rademamj1, how did you find the info on the amount of flow shared to the power steering? I am trying to compare various makes and models, but Kioti just lists the total pump capacity.
/ Hydraulic flow rate loss for 3rd function #7
DK4510 Operator Manual:
Shop Manual:
In typical Kioti fashion, the Operating manual and shop manual do not agree (at least in gpm conversion).
/ Hydraulic flow rate loss for 3rd function #8
Thanks. It is also not very convenient, but I can work with this.
Richie 300 Cattle Water Tank (A65640)
Richie 300 Cattle...
School bus (A64194)
School bus (A64194)
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
(10) Massey Ferguson Tractor Weights (A65640)
(10) Massey...
2022 EZ-GO ELITE...
2006 Chevrolet C5500 Service Truck, VIN # 1GBE5E3256F423684 (A65563)
2006 Chevrolet...
