Another Grapple Weight Question
/ Another Grapple Weight Question #1
Matt VA
Member
Virginia
2021 Branson 4820CH
I am getting a branson 4820HC. Heavy for its class and lift capacity of 2700. Dealer is trying to sell me a 66 inch wr long grapple. It weighs about 670 pounds. Grapple will be for clearing brush and lifting logs for a mill I have. Too heavy? I'm struggling to decide. Dealer says I will want the heft as he sees lighter 300 to 400 lbs grapples get bent.
/ Another Grapple Weight Question #2
One of the best 400 pound grapples might hold up but a cheap mild steel construction one won’t.
/ Another Grapple Weight Question #3
Weight does not always equal strength. A grapple made with cheap steel has to be heavy to have any chance at all of survival. A grapple made with high quality steel does not need to be heavy to be very strong, especially if the design is good. A lot of cheap grapples are made heavy to try to get by with the crappy steel they're made out of.
Understood. My understanding is that the wr long grapple is higher end with better steel. It's just very heavy duty. I see an EA wicked 60 inch at 400 pounds -- 230 pounds less than the grapple I am currently looking at and wondering if that's not the way to go.
/ Another Grapple Weight Question #5
Lift capacity where? Max height 20in from the pins or at pins or breakout force? 2700 I am guessing max height at pins, but it matters. How heavy are the logs you need to lift? How high do you need to grab/lift them? Do you have ballast on the tractor for the heavy ones? Just covering the bases.
Mine weighs 900 lbs but it is made for a skid steer. It is fairly bulletproof.
Yes. 2700 at the pins. Will be running fluid in the tired and 900 lbs at the back for additional ballast. I would keep logs to 10 feet long and perhaps 18 to 24 inches
/ Another Grapple Weight Question #7
I have not bent my Wicked 60" root grapple (the long tine type). The lids still meet the teeth perfectly. My Branson has the older 2200lb capacity loader. I've picked up logs that it could barely lift and could not curl. I think 60" is as wide as I need.
/ Another Grapple Weight Question #8
I have a Land Pride SGC1560 on my Kubota M6040. It VERY HD - made with AR400 steel and weighs 820#. A couple reasons I chose this grapple. It's not going to crumple up when I use it. Soo... Buy once/cry once. It WAS an expensive grapple along with the WR Long 3rd function valve. And - it was available thru the local Kubota dealership. Any after sale service is an important factor to me.
I DO NOT lift heavy "things" up high. So...... this means I can lift a 3000# rock or chunk of tree trunk just off the ground and move it. At this weight I can lift to a height of around 30". As with all lifting - the higher you lift - the less you can lift.
I've had this grapple for seven years. Only "damage" - the paint keeps wearing off the tips of the teeth.
If I were to do it again - I'd buy the same grapple and 3rd function valve.
/ Another Grapple Weight Question #9
Get your FEL OP Manual. It should have "weight lift" charts. You know how high you are going to lift. These charts will tell you exactly how much weight and how high. What is listed on the general spec sheet is usually - 24" ahead of the lift pins and 36" off the ground.
This may not be the way you are going to use the grapple. Center of mass on my grapple is around 16" ahead of the lift pins - it makes a CONSIDERABLE difference.
/ Another Grapple Weight Question #10
I would highly recommend the EA Grapple. I have the 55” Wicket Root Grapple I use on my Branson 4815C and love it!
/ Another Grapple Weight Question #11
...Dealer is trying to sell me a 66 inch wr long grapple. It weighs about 670 pounds....
Sounds like he has one on the lot he is trying to get rid of?? 66" is great if you need to pickup lots of brush/trash at a time. 66" is not so good if you work in tight spaces (the woods).
I love WR Long products, I have their Bolt on Grapple on my bucket. I've been to their office in Tarboro, NC and seen them making stuff in their factory... Good company.
/ Another Grapple Weight Question #12
And width of the grapple, if anything increases the likelihood of bending. As it 1) increases what you think you can pickup
2) allows more leverage in the mild steel from its support frame.
Bottom line bigger and heavier no not equal stronger.
/ Another Grapple Weight Question #13
I think you will be fine, have a 66 inch L style grapple on my 55 HP Rhino tractor and have lifted a few 28-30 inch by 14 foot pines without a problem.
That said , if you will not be moving lots of brush in addition to logs , i would probably get a bit narrower grapple as others have suggested.
If you will be moving some brush regularly then a 66 inch grapple may be a good width.
/ Another Grapple Weight Question #14
I have the W.R. Long open bottom, 2 clamshell grapple on my MX5200. I have never tried to lift something that wouldn't go, and the times I did it was ballast limited not loader capacity. It has been a great grapple. Great for brush. The longer tines on the bottom let you dump the bucket down and come down and in on a pile to let you rake it up as you go.
/ Another Grapple Weight Question #15
Well for what its worth I have had a 48" Wildkat Economy grapple. I got in on ground floor 9 years ago and paid 700 bucks delivered to Mass. Only issue I ever had was I was trying to "hog out" a buried bolder by opening all the way and digging with teeth while trying to roll back with grapple locked onforward edge of rock I cracked the welds where cylinder is attached to box beam. Cut a couple of 1/4" thick wedges and welded on-end of problem. As my avatar shows you can get a lot of firewood on it Like you, I use it for clearing brush as well as bucking logs. I'll take the weight savings (350lbs) any day vs lost payload with a heavier, wider grapple.
/ Another Grapple Weight Question #16
My 584 IH weighs about double the weight of the Branson,,
I think my real lift capacity is about 2,200 pounds.
I built a metal building, and asked the guy sending me the steel not to palletize the material over a ton per bundle (it was beams, so the weight was easily known).
I struggled to unload the truck when it arrived, because the unloading spot was not level.
I would not want to handle 2,700 pounds with a tractor that weighs 4,400 pounds,,
after having handled 2,200 pounds with an 8,000 pound+ tractor.
Actually, I would spend that grapple money getting a heavier model of tractor now,,
then, later get a grapple,, after a lot of reading a lot of reviews,,
/ Another Grapple Weight Question #17
The OP's Branson will end up being more like 6000 lbs with loader, filled tires and the counterweight on the back. I've carried around a lot of IBC totes filled with firewood that weigh about 2000 lbs. My 3725 is the same frame size as the Branson the OP is buying. Mine has filled rear tires and a 550lb weight on the back, but as an open station model it's not got the cab. While I know the weight is out there and I'm careful with it, the rear end doesn't get too light and it handles uneven terrain ok. I'd be fine with another 500 lbs on the loader if I had a heavier counterweight.
/ Another Grapple Weight Question #18
I recommend a Hound Dog Grapple from MIE. I ordered a 48" in custom color to save weight and I appreciate the lack of width more than I feared it wouldn't be enough. IMO it's not gonna break if it hasn't after 5 years of tractor tipping use.
That said I rarely move 10" logs >16' long or way-thicker ones much > than 6-8'. My loader is weak for size, but I can curl to get heavy rocks just up enough to skid them. Most anything I can lift at all I can lift to near full height, always enough to load on a trailer or into a truck. (Not my job to unload)
Note that the cyl base pin and lid pivot shaft are anchored to extensions of the teeth vs to welded-on brackets. I have a hanging scale and can weight it off the pallet next time I hook it up. It tends to stay on my #1 tractor for the Summer, switched only for the other grapple. (tree Puller)
Im going to go with the WR Long for now. Dealer said we could do a swap if I am uncomfortable with it.
/ Another Grapple Weight Question #20
You won't beat that deal anywhere. Matt - be sure you REALLY need that 66" grapple. A 60" grapple is going to do everything that a 66" will. The 60" will weigh around 70# less.
I've heard good reports on WR Long grapples also. You will be surprised how handy a grapple is.
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2018 International LT Automatic Day Cab (A62613)
2018 International...
