200 acre property, Considering a M-5 111
/ 200 acre property, Considering a M-5 111 #1
MoabMan
Kubota
200 acre property, will run a batwing mower, What brand would you suggest need it to knock down 4 inch sage and rabbit brush, no one has a 12-15 batwing in stock so I will need to order it any feedback on reliabiltiy and brand would be appreciated, would like to disc and seed, any feedback appreciated on my consideration of the M-5 Kubota.
thank you.
MoabMan
/ 200 acre property, Considering a M-5 111 #2
For that size tractor and a whole lot of mowing - Schulte Industries, rotary cutters. My neighbor has a couple of those bat wing, lime green implements. He says they work well and just require routine maintenance.
/ 200 acre property, Considering a M-5 111 #3
thank you.
MoabMan
Hard to beat Woods and Bush Hog.
I bought a Woods BW15.50 about two years ago and have found it to be all it was advertised to be.
Woods has a proprietary blade mounting system that makes it easy to change blades even after years of use.
The BW is my 4th new Woods cutter in the past 12/13 years and I have had no serious problems and few regrets.
Prices for new implements are skyrocketing so delay is costly.
SDT
/ 200 acre property, Considering a M-5 111 #4
I have used John Deere CX series rotary cutters for decades behind my Kubotas and JCBs.
I am a commercial field cutting contractor and farmer, so what would I know, but I am pleased with them.
Its easy to beat Woods. Just take a single deck woods into some rough junk and see what the deck looks like. I hear they may finally have a double deck design, but the others had it 15 years ago.....
Bush hog is a very good brand.
/ 200 acre property, Considering a M-5 111 #5
Just to show you I have experience with Woods, here’s one of my Kubotas about 8 years ago with my Woods mower. The deck did not hold up. It began rusting on the top from rock hits in 2 years.
My Deere’s have no rust, because of the dual deck design after 10 years of hard commercial use.
/ 200 acre property, Considering a M-5 111 #6
I have run both jd and woods rotary mowers. Both pull and 3pth. I will go with woods. I used to mow pipeline row and jd didn’t get it . Regardless of there double decks .. there gear boxes are junk. Woods is tough.. I have owned 4 and will put them up against any of the major brands. ROW mowing is tough and hard on mowers and tractors.. the ground is unforgiving and steep. The mowers we use cut 4” and down materials and no problems with deck dents or other issues. You can’t beat there blade change systems either. Jd is good by 2 ways their name and their paint . They like both!
/ 200 acre property, Considering a M-5 111 #7
Just used our M-5 111 for the first time today spreading fertilizer. I don’t know how people keep the plastic on their seats. The static electricity that is produced is too much for me to handle. Every time I went to open the door I got shocked. The plastic comes off tomorrow lol.
I felt the PTO shifter for the 540E or 540 was very finicky. Maybe just because it is new but after shifting and it not engaging but grinding gears I think I’ll leave it on the good old 540.
The tractor was comfortable to drive and got the job done once I figured out the PTO. Happy with the radial tires as it just seemed to float on top of the ground.
After 10 or so hours the DPF is 60% full. Not sure if the regen kicks in at 100% or a little before. When the tractor is pulling a load it’s DPF doesn’t fill up as quickly.
/ 200 acre property, Considering a M-5 111 #8
The plastic on my seats came off immediately. Wife took a bath towel and sewed me a seat cover to protect the velour seat. Works very well.
/ 200 acre property, Considering a M-5 111 #9
Operators manual advises to stop engine before shifting EPTO selector.
SDT
/ 200 acre property, Considering a M-5 111 #10
Is a bat wing mower all you will consider??
A Hiniker 15 foot flail shredder has many fewer fewer drive components and only one gearbox and can be 3 point hitch mounted or towed and it has an optional towing hitch and a road legal lighting system for towing that allows it to be towed safely within the roadway width.
/ 200 acre property, Considering a M-5 111 #11
I just went with a Kubota/Landpride 12ft. I had one spindle tranny bearing go out, but..... I tried to mow a t-post with so not really their fault.
What does tick me off is bush hogging & the batwing never can pull up the grass that my tires run over, so the pasture has strips of long grass the next day after a fresh cut! Drives me up the wall.
The only thing I can think to do is buy some blades that have more of a curve on the trailing edge so it might suck the grass up better & give me a cleaner cut.
Steve
/ 200 acre property, Considering a M-5 111 #12
Where are you located? My dealer for the most part keeps a couple 15 foot batwing BH cutters on the yard along with a fold up offset. He sells a lot of them to the highway grass contractors. They are quite pricey IMHO. I think my cousin, who does that, paid $88,000 for the four he just bought.
/ 200 acre property, Considering a M-5 111 #13
Steve
I have very little such problems with my Woods BW15.50. Three point mowers, yes. BW, no. Indeed, the BW cuts much more cleanly than my 5', 6', or 7' mounted cutters.
Ground speed too fast?
/ 200 acre property, Considering a M-5 111 #14
What sort of tractor did you end to getting?
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A59230)
2007 Western Star...
Swict 66in. Skid Steer Bucket Attachment (A59228)
Swict 66in. Skid...
Pat's QH and hydraulic top-link.
Pat's QH and...
