Compact telehandler
/ Compact telehandler #281
Sharing more pictures.
This big oak has had less live branches every year. Hear is a picture from five years ago:
This year it didn't have any leaves on it anywhere:
Put the stump bucket on the V417, raised the boom to 45 degrees and put the stump bucket against the trunk:
Got in the cab (FOPS), extended the boom about six inches and saw the crack in the ground:
Reached in and extended some more:
Roots are dead, it is going over easy:
That's crazy that you could push over a tree that big with a piece of equipment that size. Thanks for the pics.
Rob
Should have commented back when this was posted. The reason is the hydraulic cylinder that extends the boom.
Even at idle it has enough power to slide the heavy V417 backwards, if what it is pushing on doesn't move:
/ Compact telehandler #282
does anyone know:
1. does the v417 have a case drain?
2. 22 gpm stated flow-is that the flow to the aux, or the hydraulics specs of the machine?
3. is it a tandem pump or singular pump?
thanks for the help! im trying to see if an implement is compatible.
/ Compact telehandler #283
does anyone know:
No case drain:
Aux.
Look it up here: Bobcat Genuine Parts Catalog – Official Bobcat Company site
There are workarounds for no case drain, but I have never needed it.
/ Compact telehandler #284
thank you xfaxman!
/ Compact telehandler #285
You're welcome, glad to help.
/ Compact telehandler #286
has anyone had to replace the front windshield? reason is mine got busted in transport and is at the bobcat dealership now in atlanta. they've never seen a V417, but it looks like it shouldnt be out of their wheelhouse. anything i should be worried about/look out for from anyone's experience on here? thanks!
/ Compact telehandler #287
I guess nobody has had to replace the windshield.
We need an update on yours and did you get a mower for it?
Just to refresh your memory on my 7' brush hog:
/ Compact telehandler #288
it arrived last weekend! i only had time to put 6-7 hours on it. started clearing off my old burn pile-went places i would never go with my tractor! inclines, ditches, over stuff that would have rolled my tractor-love this machine. the only attachment i have so far is the 72" bucket it came with, with bolt on cutting edge.
i purchased a quick attach 72" brush buster, should be delivered first week of november. Loflin Fab grapple, stump bucket, and pallet forks coming also-super nice folks. right now, work is getting in the way form getting projects done
did my picture come thru? if not, maybe someone could provide guidance. thanks!
/ Compact telehandler #289
Yep, picture posted, looks good OK.JPG.
/ Compact telehandler #290
A quick and easy job for the Long Arm Tree Puller:
/ Compact telehandler #291
I finally got a roundtuit and took pictures to show how small it is.
Lined up the front with my wife's 2016 Ram 2500:
This shot shows how much shorter the V417 is:
And this shows that the V417 is not as tall as the Ram:
/ Compact telehandler #292
Ive put about 40 hours on her so far. Dont see me going back to tractor
She’s developed a problem...
When i let off brake, she goes like she”s pointed toward the barn. Usu, when i let off the brake, the parking break kicks in to stop her. All fluids are adequate...any ideas?
/ Compact telehandler #293
Does it move normally when operating it?
Is it completely stopped and idling before you let off the brake?
Shift to neutral, let off the brake pedal, do the RPMs increase??
I rarely step on the brake pedal when driving, because letting off the accelerator applies the brakes at idle.
There is only one set of brakes even though there is a switch and a light on the dash labeled Park.
/ Compact telehandler #294
First, thank you for the timely response!!!
Ok, we are all friends here, right? I hesitate to reveal my mistake, but goes to show me how, when in a hurry, the obvious gets overlooked
I had found these posts in a field and put them in the cab, and as you can see, one was jammed at the accelerator pedal...eye roll please...i deserve it
Did i say how much fun this machine is?
next project is getting getting front/rear cameras
/ Compact telehandler #295
Well - those are the kind of fixes we all want to find! Easy.
Those are great machines.
MoKelly
/ Compact telehandler #296
Yep, the post about the post makes me feel better about the machine. (y)
That may be the easiest fix that you will ever do!
/ Compact telehandler #297
I'll tell ya, these tele handlers beat a tractors versatility hands down. Now if you could only take them in dense woods and use them to skid logs, it'll be a life long crush for me.
/ Compact telehandler #298
Since the compact telehandlers are smaller and have four wheel steering, they will go in the dense woods where a tractor can't go.
And put this on the front: skid steer forestry winch - Image Search
And this on the rear:
/ Compact telehandler #299
Yep, with 4 wheel steering, even my big Lull can maneuver lots more readily than my Mahindra.
It's shorter too.
hugs, Brandi
/ Compact telehandler #300
I guess my first concern was ground clearance.
How would one go about lifting and walking a hitch of stems out of the woods with such a conveyance?
Or I'm I asking too much of this magical machine?
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
CrusterBuster 4000 Grain Drill (A63118)
CrusterBuster 4000...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A64047)
Kuhn Axis 50.2...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
