Grapple for Working in the Woods
/ Grapple for Working in the Woods #21
Yes Sir, I respect what you posted...and have learned to value most everything else you post. You seem to do it right.
Life's too short to start a debate about grapples, which is why I put my comments as just my view of this wonderful world.
Actually it was you and Mr. SaywerRob I was thinking about when I said some cut the big stuff and have different needs. And I know you wouldn't use something that wasn't quality.
Wishing you a Good Night Mr. Gould, with as much sincerity as I can convey on a forum post.
/ Grapple for Working in the Woods #22
Almost forgot - works fine building bush piles too
gg
/ Grapple for Working in the Woods #23
I appreciate that. Things are complicated and often not exactly what they seem intuitively. This is a great learning place so don't take my post as a criticism or belittlement.
gg
The differing opinions that are given in these forums is what makes them such a great source of information. Real life experience with a particular design, size or project are invaluable but at the end of the day we make the choice best suited to our application. Many times there is no best choice. It痴 always a trade-off of one feature for another but having accurate information and experience to make the choice is why we all come here.
Now getting back to the subject of the thread, I actually would have a use for both a wide and narrow grapple rake as well as the FrostBite design but can稚 afford to have all three sitting around.....so based on my property needs, which only I know in detail, I値l pick a style and size that 澱est suits my needs.
Keep the great insights coming guys.
Bruce.
/ Grapple for Working in the Woods #26
I may misunderstand GG's description of picking up a log on uneven ground, but I often reach down from the top, rather than trying to scoop it up. That comes in especially handy when stacking 9 foot lengths, as I can stack four or five at a time, then reach down and pick all of them up.
/ Grapple for Working in the Woods #27
I got a 60" wide grapple. I feel it does not need to be wider for my uses. 55" would be fine too.
/ Grapple for Working in the Woods #28
I have an MTL grapple. 55 inch single. This has worked well for me in prying stumps, grabbing logs, grabbing brush. It may not have the same quality as an EA, but it is also less than half the price and available right away.
Recommend that you leave about 5 feet of trunk so that you can shove the tree over with the grapple before digging down into the roots and pulling up. Even with loaded tires and something heavy on the 3pt hitch, you may lift your rear tires up. So take it slow at first. Your tractor has the loader and about the same weight as my 4520r. It is a very stout tractor.
I pulled out dozens of spruce and birch with mine. But the roots of your Georgia hardwoods might be a little more tough to pull up.
Depending on how much money you have to play with and how much logging you are doing, a skidder is a great investment. I want one.
Congratulations on the tractor.
/ Grapple for Working in the Woods #29
The differing opinions that are given in these forums is what makes them such a great source of information. Real life experience with a particular design, size or project are invaluable but at the end of the day we make the choice best suited to our application. Many times there is no best choice. Itç—´ always a trade-off of one feature for another but having accurate information and experience to make the choice is why we all come here.
Bruce.
Well said !!
gg
/ Grapple for Working in the Woods #30
I own a Sundown GR40 grapple. It's very similar to the Frostbite mentioned earlier. There is nothing better for maneuvering in the woods, and they hold logs securely - they ought to as that is exactly what they are designed to do. The extra maneuverability is a much bigger factor than you might imagine, I can thread into places that I could never come close to with my bucket on the tractor. The trade off is that while you can pick up a good grab of brush with one of these, you can't really "rake" at all (though I have been known to grab some cedar or pine tops with my grapple to use as a broom on occasion). Other styles of grapples will let you rake up debris and pick up smaller rocks and debris, or carry a load of firewood. That just doesn't happen with a forestry grapple.
For me and for my uses, there was no hesitation: a forestry grapple is the way to go. For others with different needs, other designs make more sense. While it would be nice to have one for every need, but you learn to adapt and find ways to make what you have work for you.
I can understand where EA grapples are preferred but at almost half the price at the cost of 100lb lift loss, I am thinking wouldnt the following be a better deal?
MTL Attachments John Deere Compact Tractor 48" Root/Rake Grapple Bucket — MTL Attachments
I did look at and consider the MTL brand but when I made the choice to go with the rake style grapple with the short lower tines vs the log style with longer tines, it limited my choices.
The next biggest factors on my list is then weight followed by stiffness/strength of those lower tines since I plan to to drop it into the ground and push up small roots in the hard Georgia red clay we have around here. Some designs have short lower tines but they are not well braced right at the ground level. Those that are weight significantly more than the EA. I am a complete novice with tractors and attachments but as a mechanical engineer I understand the differences in steel strength and which design configurations are going to be stronger for my intended use.
I have no doubt many others here have the same level of knowledge as well as real life experience using the tools. That痴 why I知 here listening and learning.
Bruce.
/ Grapple for Working in the Woods #33
If I were you I would check out very carefully your tractors ability to push a root rake below the surface to grub up roots. I know terrain, soils, vegetation type, and root mat very greatly and can't know what you have. But I could not do it here with my 5000 lb L3010 with what we have unless I used something else to break up the ground first. Just saying be conservative and make sure make so you won't be disappointed. I have a small 14,500 lb dozer with a root rake and it is hard work for that.
gg
gg
Great point and one I think will be a real possibility which is why I wanted something stiff so there would less chance of damage when I get hung on something too big to move. In addition to grubbing, I have so much surface vegetation, small brush and tree debris to contend with that I am pretty sure it will still be my Go-To implement along with an HD box blade with ripper teeth.
I can foresee renting or hiring a bulldozer to get some areas initially broken up enough that I can finish with my tools but that too may not work out the way I think. Looking forward to figuring it out though.
Bruce.
/ Grapple for Working in the Woods #35
There are definite limits as to ground engaging work I can do with a grapple. I loose traction long before I bend my mild steel MTL grapple bends.
/ Grapple for Working in the Woods #36
Thats what I was thinking also. My tractor tires just start spinning and loose traction. For the the $1k diff in grapples pays for diverter kit.
/ Grapple for Working in the Woods #37
OP,
There are many smaller outfits that build grapples. Check Craig’s list and someone will have their products advertised.
My issue with EA is the lead time. I personally would not wait a year.
I tried to go with EA but I could not get anything from them in time.
/ Grapple for Working in the Woods #38
OP,
A year? Lol.
Albeit, they do have a longer than standard lead time, it's never been anywhere close to a year. When I bought mine in the fall of 19 it was 6 weeks, received in 4. Pretty sure it's the same now.....
/ Grapple for Working in the Woods #39
A year? Lol.
When I was looking they were a couple of months out. The 50% interest free loan to them was one reason I went with an MTL, and had it a week later. In ten years of working for myself I never had anybody pay me for work before I completed it, and never even considered asking.
/ Grapple for Working in the Woods #40
A year? Lol.
Maybe I seen 12 weeks and not 12 months
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
