Wooden Bridge Question
   / Wooden Bridge Question #11
I eliminated what wasn't important in your question, and left what matters. How far is the span of your 2x8 beams? From memory, you can go 16 feet with a 2x8 for a roof, but not a floor.
from what you have given, I would guess that your max load will be in the one hundred to two hundred pound range. I would be nervous walking across it. I doubt that I would carry a hammer or anything heavy if I walked across it. I would not let livestock walk across it. Maybe my dog, but only one at a time.
Max span for SPF 2x8 floor joists @16" OC, is 12'
   / Wooden Bridge Question #12
So that would mean that the bridge would have to have support for the bridge every 12 feet for the 2x8's to rest on. Then there would have to be 2x8 joists every 16 inches apart for the width of the bridge. 8 foot wide bridge would have to have 7 2x8's for every 12 feet of length. 8 feet isn't wide enough to drive across in my opinion, but it's easy math for this situation.
You didn't mention what the rating is for that span, but if it's for a house, it should be strong enough to walk across and maybe handle a riding mower. I wouldn't trust a tractor or even a side by side ATV on it. I have a bridge that I'm going to make for my overflow dam at my pond and for 12 feet of span, I am going to use treated 2x10 every 12 inches so I can drive my zero turn and Kawasaki Mule over it. I will not drive my 35 hp tractor over it.
This also relies on the posts in the ground being strong enough to support the load of the bridge and what's on it, every 12 feet, for the length of the bridge.
   / Wooden Bridge Question #13
^ eddie, he said he has a full grid of 4x6 posts - every 6' along the bridge length, and every 5' across the width. So I presume this means he has a 10' wide bridge with rows of 3 posts every 6 feet. The 2x8s probably go sideways to connect the posts, and then he has six 2x6s going 6' between every row of posts.
I'm most concerned with the 1x6 decking. I would never drive a heavy vehicle on 1x6s spanning over a foot between joists.
   / Wooden Bridge Question #14
If the 1x6 decking should fail, it would only be ugly, and messy.
If the supporting structure failed it would be DANGEROUS!
   / Wooden Bridge Question #15
Thank you, that means I got it all wrong.
   / Wooden Bridge Question #16
   / Wooden Bridge Question #17
Nah, it's a pretty confusing description, I'm not sure I got it right either.
What I am wondering is why the bridge needs to be 52' long if you have solid ground to place posts in every 6'.... I guess it's more like an elevated causeway, or trestle bridge.
   / Wooden Bridge Question #18
Do you have pics of the bridges? Maybe a drawing showing the posts and any support beams connecting the posts?
   / Wooden Bridge Question #19
I don't have a clue about load bearing capacity, but 1" decking is a very limiting factor. 52' seems quite long for a creek crossing. Could you please post pics? I have seen similar posts recommend using a scrapped semi trailer for the bridge underpinnings. Was that something you considered?
   / Wooden Bridge Question #20
It would be nice if the member who started this would come back with some clarification, that is, if we haven't scared him to death already. If I understand this correctly, the structure has a bunch of 4x6 posts, connected by 2x8s, with 2x6 joists supported by the 2x8s. Then it has 1 x 6 decking on the 2x6s. If the 1x6s have a maximum span of 1 foot across joists, a rough calculation indicates they should take about 1000 lb load. With the 2x8s good for about 3500 lbs, as I calculated above, the 1x6s should handle wheel loads.
I would have used 2x6s but this is probably OK for the zero turn. Of course, if the connections are not well made for any of this, it all goes out the window (or into the creek).
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56435)
2019 BOBCAT T630...
