Electric Power Washer Recommendation?
   / Electric Power Washer Recommendation? #31
Yup, the difference between the commercial and homeowner markets.
   / Electric Power Washer Recommendation? #32
That Karcher commercial looks very nice, with functional vs. pretty packaging
   / Electric Power Washer Recommendation? #33
Why are most only for cold water?
I think it would be great to use water from our water heater to help the cleaning process.
The only pressure wash I have really used was a commercial stationary unit from Hotsey back in the late 70s and early 80s that had its own burner to heat the water.
   / Electric Power Washer Recommendation? #34
Based on a quick search, cold water pressure washers can be connected to hot water as long as the temp is less than 140F.
   / Electric Power Washer Recommendation? #35
A cold unit can build up temperatures in a hurry while in bypass. Hot water would hasten this process, I'm guessing.
   / Electric Power Washer Recommendation? #36
Yep......and by the time your domestic hot water reaches the pressure washer inlet, it will always be less than 140 degrees.
   / Electric Power Washer Recommendation? #37
I have had many gas one over the years. Wife needs me to start it...........last spring went with a ryobi electric from the depot. Actually works good and easy to use for
Cleaning stuff like wood and vinyl fences, decks, retaining wall blocks and pavers.
I still have the gasser for me....
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
KUBOTA M900 TRACTOR (A59823)
KUBOTA M900...
