When to use four wheel drive?
/ When to use four wheel drive? #222
I'm SELDOM in 4WD. I would guess it depends upon where you are and the terrain. My 80 acres is pretty flat with a few valleys here & there. There are places I will not go - even in 4WD. I can get to some of the difficult places with my ATV but it's a REAL heart pounder. There are cliffs on my property that would take a skilled climber to navigate. The cliffs are completely vertical and I stay away from them with all forms of vehicles. A pictures of parts of my property. See that red dots in the little "valleys" in the cliffs on the far side. Not even on the ATV. I tried it once and "WE" almost rolled down into the lake. The cliffs on both sides of the lake - stay the heck away from the tops of them. The dirt will slide off the bedrock and you will be in the lake in a heartbeat. The lake is 80 feet deep.
You can say - "Well, it's obvious you shouldn't have vehicles up on those cliff tops". Not to some. I've had IDIOTS drive their pickups right up to the cliff edge on this side of the lake. Makes me so dam mad. If that vehicle fell into the lake there would be oil contamination forever. Bodies float and could be fished out.
View attachment 683529View attachment 683530.
I've seen that terrain and I wouldn't get close either. In my case, I am seldom NOT in 4WD. Only when I get up on my paved driveway to I shift out of it and I shift back in as soon as off road. A couple of out of control rides down the hill convinced me I don't want to remember too late.
/ When to use four wheel drive? #223
I'm with ya dragon eggs. We have no flat land... The only place we put things in 2 wheel drive is when we are on the concrete around the barn and garage. 4WD has saved me a couple times when the rookie operator did something dumb! The brakes do not hold when on our hills. I like the feel of the geared tranny and 4WD.
/ When to use four wheel drive? #224
That's some beautiful property Mr. Oosik.
An 80 foot deep lake on personal property is somewhat unique and quite special.
/ When to use four wheel drive? #225
It was interesting the other day to be clearing snow in a ~10,000 tractor and be sliding backwards down a slight slope with the brakes locked...
Aaron Z
/ When to use four wheel drive? #226
Aaron Z
No chains, that will happen.
Doesn't matter what your on I've 20,000+ pounds decide to do it's own thing,
and I watched a neighbor with a big articulate on duals that couldn't even get out of his own way.
Wet snow that packs into ice doesn't respect anything but chains.
/ When to use four wheel drive? #227
Aaron Z
The coefficient of friction is greater for static conditions than kinetic.
That’s a way of saying: A tire that isn’t skidding (static) has more grip than a skidding (kinetic) tire. Pump your brakes. The principle of ABS.
Of course, sometimes on ice, both coefficients are so low, it might not matter very much.
(Now I know someone will say ABS stopping power is worse on ice than skidding. This is often true because it’s not braking more than it is; it can’t brake as sensitively without skidding then releasing.)
/ When to use four wheel drive? #228
Aaron Z
Around my place, if I start sliding in my tractor, the last thing I would call it is 'interesting'! :eek: :laughing:
/ When to use four wheel drive? #230
It’ usually best to engage four wheel drive before it is required.
When talking about pickups, that rule also applies to deactivating the traction control. Don't ask me how I know that! :shocked:
/ When to use four wheel drive? #231
Don't you just really like it when you almost get over the hard spot and all of sudden the truck decides it shouldn't spin a tire any more and cuts the power right off so you just stop right in the worst spot.
/ When to use four wheel drive? #232
We haven't had snow in a week, and that was about 3 inches; there's less than a foot on the ground and I"ve been driving everywhere so never expected it to have drifted the way that it did. The worst part was that I was on the back side of a field, easily visible from the highway. If nobody had seen it, it never would have happened.
/ When to use four wheel drive? #233
Only use the 4wd when in good pulls and pushes or when such is eminent. When the spin catches you off-guard while in 2wd always stop, pull the lever, push the button. Stay calm, 4wd on...:D
/ When to use four wheel drive? #234
It really comes down to knowing the limitations of vehicle and driver. Most of us learn those limitations by digging ourselves out a few times... ;)
/ When to use four wheel drive? #235
I still struggle to remember to deactivate the traction control even though I have had since 2009. I think it is because my 1993 which is the truck I usually take off road. The few times times the 09 is off pavement I just do not think about it. I really like my old school 93. I can back into anything, leave the seat belt off, etc and it never beeps at me.
/ When to use four wheel drive? #237
Many trucks of '93 vintage had their own issues... namely the vacuum diaphragm system which replaced locking hubs. I got hung up on more than one occasion because the front end didn't engage when I needed it… I finally pulled one line, used my air compressor to lock the front end in then capped it off. A coworker spent the night in the woods after getting stuck because as he went from 4H to 4L the frontend disengaged and wouldn't go back in again.
/ When to use four wheel drive? #238
I ordered my 1993 with a good old floor shifter for the four wheel drive. Last year I could not get it in four low. I removed the entire shifter assembly. A toothbrush and a little grease and she shifts like butter. Probably good for another 28 years.
/ When to use four wheel drive? #239
My 2018 company truck has the same floor shifter. Even those aren't foolproof. One of my previous company trucks got stuck in 4 low... it was a long ride out of the woods that day.
/ When to use four wheel drive? #240
It took 27 years for mine to give me trouble. It was a pain to remove it. Almost 30 years of grit had all but frozen the shifter.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60432)
KNOW BEFORE YOU...
TOWABLE HYD WOOD SPLITTER (A60430)
TOWABLE HYD WOOD...
Zato Hydraulic Demolition Shears Excavator Attachment (A59228)
Zato Hydraulic...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
