Pressure Washer Heated Storage
/ Pressure Washer Heated Storage #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a small PTO powered pressure washer. I want to use it in winter, but my garage gets close the freezing often.
I thought about having a 100 watt bulb in a small insulated wooden box. But I am not sure that would work.
Any other ideas.
/ Pressure Washer Heated Storage #2
I used to store my electric commercial pressure washer in an upstairs heated room in my barn. What a PITA!
Now I just blow it out with compressed air. I have made up special adapters for the air line AND I run the machine while blowing it out. No issues in fifteen years or so.
/ Pressure Washer Heated Storage #3
They sell small pressure cans of pressure washer antifreeze at lowes and HD. screw in tube from can squirt till foam cones out. Easy peasy
/ Pressure Washer Heated Storage #4
You have to protect the hose and wand too. That would be a lot of antifreeze. I made up air hose to high pressure adapters for that too.
/ Pressure Washer Heated Storage #5
No, the wand and hose i blow out with shop air. Ive done this for 10 years. I use mine in winter all the time.
/ Pressure Washer Heated Storage #6
Why not just blow the washer out with compressed air also. I've been doing this for 20 years. Compressed air is cheaper than antifreeze.
/ Pressure Washer Heated Storage #7
On portables, trucks we used to recirc anti freeze in a bucket. You can blow them out, can use heat which is my preference. Use 2 lamps in series though. I have one in an insulated box on a truck doubles as a fire truck but have the shop inside and heated, hose thru wall with outside controls. 5 gpm @ 200 degrees, can melt ice and clean grease. I wash a car about every day.
/ Pressure Washer Heated Storage #8
I just never thought of doing that. I pay about $5 for a can of winterizer. A can last me about 4-5 seasons...or more. Only takes a squirt. I never worried about the hoses and wands cause even if some water remained, it wont expand enough to crack. I always worried about water expansion damage to pressure washer though. What i should do is simply store it in my heated tack room.....but too lazy to walk that far.
/ Pressure Washer Heated Storage #9
Holy crap....now thats a pressure washer.
/ Pressure Washer Heated Storage #10
It does so much work and compared to the depreciation on just one new car it's nothing. If I was starting over and going to pay men would get 1 size bigger and connect to L.P. it's kind of a run what you being kind of deal though, I got it in my mid 20s and had visions of some kind of portable. I used it remote about twice, never moves. 100 ft hose.
/ Pressure Washer Heated Storage #11
The portable is 80%the shop unit. I can feel the difference but it's minor considering the use. I didn't use it today, so far. It's a bit like compressed air, not cheap or energy " effecient" but does so much work so fast and well. Can hyper wash and get something sterile clean that itd rare to really dirty my solvent tank.
/ Pressure Washer Heated Storage #12
I was a little concerned lately. I started to have a problem with the relief valve sticking on my CAT pump pressure washer. And despite (I believe) having blown it out, there was water in that relief circuit and short hose. Yet, if that doesn't get blown out with compressed air, it's never been a problem.
/ Pressure Washer Heated Storage #13
i wish all my storage areas were heated...but i would need to be elon musk to afford the fuel. I just determined that my block heater on my f350 isnt working. it took 18F night to figure that out. Now i just need to figure out if i want to tackle it or take it to shop. im getting pretty lazy lately. the block heater on a 6L f350 looks like a sucky thing to change out.
/ Pressure Washer Heated Storage #14
Energy here is expensive enough. To heat a seldom used (shop) space is a difficult, no, expensive matter. I guess, mega insulation and some forced air heating of some sort is the answer, Certainly NOT any kind of slow, major thermal mass in-Floor system. But hey, everything is about TRENDS!
/ Pressure Washer Heated Storage #15
Proly easier to change than take it.
/ Pressure Washer Heated Storage #16
I haven't found anything on my 6.0 that isn't sucky to change out. I can't even see half the stuff,how am i supposed to chage it? One day I walked over where a nieghboring camper was checking under hood of his Volvo and due to lack of accessories, accused him of having a 20 year old engine in it.
/ Pressure Washer Heated Storage #17
If my Cat pump set's idle more than a few weeks without being used,the ss discs in valves stick unless I flush it with something. For a while I used their pump flush but I've found most anything that leaves a film works so I generally use anti-freeze diluted with water.
/ Pressure Washer Heated Storage #18
i just crawled under it to look at the stupid block heater. no way in he** am i going to get any of my tools up there to get it out. i couldnt even pull out the plug to test resistance on the heater. off to the shop she goes.
2017 Case CX145D (A60462)
2017 Case CX145D...
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
