Pressure Washer Heated Storage
   / Pressure Washer Heated Storage #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a small PTO powered pressure washer. I want to use it in winter, but my garage gets close the freezing often.
I thought about having a 100 watt bulb in a small insulated wooden box. But I am not sure that would work.
Any other ideas.
   / Pressure Washer Heated Storage #2
I used to store my electric commercial pressure washer in an upstairs heated room in my barn. What a PITA!
Now I just blow it out with compressed air. I have made up special adapters for the air line AND I run the machine while blowing it out. No issues in fifteen years or so.
   / Pressure Washer Heated Storage #3
They sell small pressure cans of pressure washer antifreeze at lowes and HD. screw in tube from can squirt till foam cones out. Easy peasy
   / Pressure Washer Heated Storage #4
You have to protect the hose and wand too. That would be a lot of antifreeze. I made up air hose to high pressure adapters for that too.
   / Pressure Washer Heated Storage #5
No, the wand and hose i blow out with shop air. Ive done this for 10 years. I use mine in winter all the time.
   / Pressure Washer Heated Storage #6
Why not just blow the washer out with compressed air also. I've been doing this for 20 years. Compressed air is cheaper than antifreeze.
   / Pressure Washer Heated Storage #7
On portables, trucks we used to recirc anti freeze in a bucket. You can blow them out, can use heat which is my preference. Use 2 lamps in series though. I have one in an insulated box on a truck doubles as a fire truck but have the shop inside and heated, hose thru wall with outside controls. 5 gpm @ 200 degrees, can melt ice and clean grease. I wash a car about every day.
   / Pressure Washer Heated Storage #8
I just never thought of doing that. I pay about $5 for a can of winterizer. A can last me about 4-5 seasons...or more. Only takes a squirt. I never worried about the hoses and wands cause even if some water remained, it wont expand enough to crack. I always worried about water expansion damage to pressure washer though. What i should do is simply store it in my heated tack room.....but too lazy to walk that far.
   / Pressure Washer Heated Storage #9
Holy crap....now thats a pressure washer.
   / Pressure Washer Heated Storage #10
It does so much work and compared to the depreciation on just one new car it's nothing. If I was starting over and going to pay men would get 1 size bigger and connect to L.P. it's kind of a run what you being kind of deal though, I got it in my mid 20s and had visions of some kind of portable. I used it remote about twice, never moves. 100 ft hose.
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
378491 (A51572)
378491 (A51572)
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
HARDEE RD60M LOT NUMBER 157 (A53084)
HARDEE RD60M LOT...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
