Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #6,002
Good Morning OT Ducati,
Are you happy with your cub cadet??
How old is your woofie pie??
My mothers German Shepard was a silver/sable color that traced his AKC lineage to Rin Tin Tin.
She treated him like a fourth son in the family, she cried for days after we lost him to a heart attack in 1983.
Very happy, it's a work horse.
She's 4 and lots of fun.
/ Pictures of your snow weapons #6,004
Nice rear chains! On my little garden tractor, I run a small chain thru the center of my front chains. It helps the sideways push you get when the angled plow is pushing heavy snow.
They work well.
/ Pictures of your snow weapons #6,005
Is the orange handle in the cab your valving for the plow angle? Would like to see pics of how you fabricated the plow to the quick attach blank. I see the chain on hook for Float, like to see the pivoting points on the Blank. Trying to convince a friend to do this to his solid mount/no float setup.
/ Pictures of your snow weapons #6,006
Orange handle is throttle. I installed 3 remotes you can see the black handles by the seat.
Just come off the back of the plate(don't know why put the box over top).
Works well, floats like on a truck.
/ Pictures of your snow weapons #6,007
That is one of the more intelligent designs I've seen. Instead of everything being way out front it's now closer to the tractor. Less stress on the fel. I like it.
/ Pictures of your snow weapons #6,008
That really is a nice compact set up. I'll bet you really can move a lot of snow with that set up - above your weight class.
To be worthy of that Tractor, maybe you should paint the plow rig next summer.
/ Pictures of your snow weapons #6,009
No surprise here. I could tell by the first photo he had an "underslung" plow. Turns out a lot of people have these "underslung" versions. I hope to complete mine here in the coming week or so! The Landpride 3rd function just arrived and may very well have been the most expensive cardboard box to ever deliver to my house :)
/ Pictures of your snow weapons #6,010
Interesting off the back of the plate to keep blade tucked in close to Loader arms and as close to front tires as possible. Thanks
my weapons
/ Pictures of your snow weapons #6,011
Have a pic or two of that, and how you fasten it to the cross chains? Sounds like a good idea...
/ Pictures of your snow weapons #6,014
Finally got my JD430 restoration finished up. Last thing was to get the fabric cowling modified at the local tarp shop to make it fit better. Got it back and mounted the blower to it with the new mount that keeps the drive shaft happy when raising and lowering it.
Weatherman says we may get snow every day for the next ten days, but I'll believe it when I see it.
/ Pictures of your snow weapons #6,015
Nice work! Love to see this old equipment gain new life. Looks great!
/ Pictures of your snow weapons #6,016
Duplicate post
/ Pictures of your snow weapons #6,017
Thanks. I had the seat pan, side covers and grille blasted and powder coated. Did some other minor repairs while I was at it too.
It's a '91 model I bought in '93, used for mowing in the summer and snow removal in the winter. Got tired of swapping the snow equipment and the mower deck twice a year, so I bought a BX2230 that is on mowing and landscaping duty now.
The 430 is hardly broken in, only has a little over 1000 hours on it.
/ Pictures of your snow weapons #6,018
Hey all. Just wanted to show version 2 of my snow rig. The first was a 2016 l6060 with a 7.5 Curtis with wings. The biggest change to this new tractor is a 8-10' western wideout. The Curtis was used on the first because the mount is much narrower and fits between the front tires. The Western has a very wide mount and required some modification to fit. Western makes a mount for these tractors now but it pushes the blade way too far forward for my liking and they want like 900 bucks for it. The blade I used was the oldest wideout in our work fleet since I'd be cutting off the lights, hydraulic unit and parts of the mount. The raise and tilt is plumbed to the loader valve with flow control valves on all lines and a crossover relief on the tilt. the wings are plumbed to the rear remotes with 1/4" lines.
The other things ive done are front and rear led lights including integrated strobes with a separate strobe controller because i got tired of my old lights randomly switching patterns. The only problem is i accidently got spot beam instead of flood lights so i may change them at some point. They're all dirt cheap ebay lights anyway.
As for the Tires, these were saved from the previous tractor and ive loaded all 4 with bulk washer fluid. The tires that came with it are in storage until spring and wont be loaded. Estimated weight added is about 80lb to each front and 400 to each rear. With the estimated 1000lb weight box it puts the total weight of the tractor at around 7000 which is pretty comparable to a 8 lug pickup. The added weight makes the tractor very stable and predictable which is super important for my route because i plow around many vehicles including ambulances and news vans and really dont want to risk sliding in to anything. The only downside to such a heavy tractor is that the few places i have to plow uphill is lots to ask from 60hp.
Otherwise, the fenders were made by me for the first tractor out of a 40 dollar trailer fender and some scrap since the only set i could find was like a grand and the plow mount was just the same one i used for the curtis cut up a bit and added to. The weight box was also made of salvaged 1/4" plate and whatever scrap steel i had poured in to concrete.
So how does it perform? In wide open lots it performs about as fast as any 3/4 ton truck but, of course thats not what its for. In tight cut up lots, high traffic areas, and lots with blind corners and obstacles I cant imagine a better machine and ive plowed in just about everything including well set up skid steers and wheel loaders. If I was told that all of my accounts would be 24 hour fast food and gas stations from now on, I'd be totally fine with that.
/ Pictures of your snow weapons #6,019
Very nice. :thumbsup:
We use tractors with frame mount plows also and have found that we can give the customers a better job, faster than a pickup (visibility and maneuverability) even with the much slower travel speeds. And we're not talking about subdivision plowing either. And then there's also the NEVER getting stuck part. :cool2:
/ Pictures of your snow weapons #6,020
Nice looking rig! How did you fasten the front fenders?
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
