Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #6,011
Nice rear chains! On my little garden tractor, I run a small chain thru the center of my front chains. It helps the sideways push you get when the angled plow is pushing heavy snow.
Have a pic or two of that, and how you fasten it to the cross chains? Sounds like a good idea...
   / Pictures of your snow weapons #6,014
Finally got my JD430 restoration finished up. Last thing was to get the fabric cowling modified at the local tarp shop to make it fit better. Got it back and mounted the blower to it with the new mount that keeps the drive shaft happy when raising and lowering it.
Weatherman says we may get snow every day for the next ten days, but I'll believe it when I see it.
   / Pictures of your snow weapons #6,015
Nice work! Love to see this old equipment gain new life. Looks great!
   / Pictures of your snow weapons #6,016
Duplicate post
   / Pictures of your snow weapons #6,017
Thanks. I had the seat pan, side covers and grille blasted and powder coated. Did some other minor repairs while I was at it too.
It's a '91 model I bought in '93, used for mowing in the summer and snow removal in the winter. Got tired of swapping the snow equipment and the mower deck twice a year, so I bought a BX2230 that is on mowing and landscaping duty now.
The 430 is hardly broken in, only has a little over 1000 hours on it.
   / Pictures of your snow weapons #6,018
Hey all. Just wanted to show version 2 of my snow rig. The first was a 2016 l6060 with a 7.5 Curtis with wings. The biggest change to this new tractor is a 8-10' western wideout. The Curtis was used on the first because the mount is much narrower and fits between the front tires. The Western has a very wide mount and required some modification to fit. Western makes a mount for these tractors now but it pushes the blade way too far forward for my liking and they want like 900 bucks for it. The blade I used was the oldest wideout in our work fleet since I'd be cutting off the lights, hydraulic unit and parts of the mount. The raise and tilt is plumbed to the loader valve with flow control valves on all lines and a crossover relief on the tilt. the wings are plumbed to the rear remotes with 1/4" lines.
The other things ive done are front and rear led lights including integrated strobes with a separate strobe controller because i got tired of my old lights randomly switching patterns. The only problem is i accidently got spot beam instead of flood lights so i may change them at some point. They're all dirt cheap ebay lights anyway.
As for the Tires, these were saved from the previous tractor and ive loaded all 4 with bulk washer fluid. The tires that came with it are in storage until spring and wont be loaded. Estimated weight added is about 80lb to each front and 400 to each rear. With the estimated 1000lb weight box it puts the total weight of the tractor at around 7000 which is pretty comparable to a 8 lug pickup. The added weight makes the tractor very stable and predictable which is super important for my route because i plow around many vehicles including ambulances and news vans and really dont want to risk sliding in to anything. The only downside to such a heavy tractor is that the few places i have to plow uphill is lots to ask from 60hp.
Otherwise, the fenders were made by me for the first tractor out of a 40 dollar trailer fender and some scrap since the only set i could find was like a grand and the plow mount was just the same one i used for the curtis cut up a bit and added to. The weight box was also made of salvaged 1/4" plate and whatever scrap steel i had poured in to concrete.
So how does it perform? In wide open lots it performs about as fast as any 3/4 ton truck but, of course thats not what its for. In tight cut up lots, high traffic areas, and lots with blind corners and obstacles I cant imagine a better machine and ive plowed in just about everything including well set up skid steers and wheel loaders. If I was told that all of my accounts would be 24 hour fast food and gas stations from now on, I'd be totally fine with that.
   / Pictures of your snow weapons #6,019
Very nice. :thumbsup:
We use tractors with frame mount plows also and have found that we can give the customers a better job, faster than a pickup (visibility and maneuverability) even with the much slower travel speeds. And we're not talking about subdivision plowing either. And then there's also the NEVER getting stuck part. :cool2:
   / Pictures of your snow weapons #6,020
Nice looking rig! How did you fasten the front fenders?
UNUSED FUTURE CAT305 44" EXCAVATOR RAKE (A58376)
UNUSED FUTURE...
2013 Ford Transit Connect (A57148)
2013 Ford Transit...
12ft Continental Dual S/A Jet Ski Trailer (A56859)
12ft Continental...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
2018 John Deere 652R QuickTrak 52in Stand-On Commercial Mower (A56857)
2018 John Deere...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
