Felling a leaning tree to the side of the lean
/ Felling a leaning tree to the side of the lean #11
When dealing with leaners, I use this directional falling method:
Start with an aiming notch nonmore than 25% of the diameter on the face of the tree, this will ensure the tree falls where you intend
Then make a bore or plunge cut leaving the appropriate amount of hinge [about 10% of tree diameter] and a "holding" tab on the back side of the tree.
Insert wedges to the sides of the holding tab and drive them in solidly.
Once the wedges are loaded you can safely cut the holding tab and continue driving in the wedges thus jacking the tree against the lean.
I have sometimes doubled or tripled up the wedges depending on the amount of lean you need to overcome.
As reference, a 1 inch thick wedge can jack a 60 foot tall tree 3 feet against lean.
In a situation where the tree could possibly hit something if it fell wrong, I will put a chain on the tree, then through a snatch block and then to the tractor winch for safety.
The problem with GOL style of cutting is there’s not feedback from the tree about what that top is actually doing. If I was in the same situation as the OP I would of skipped the rigging and put a Dutchman in on the sweep side of the tree to pull it around. Another option that’s common on the west coast are jacks which involve putting your back cut in first you can do with with wedges as well. What I’m trying to get at is why work so hard back boring a tree when you really don’t need to.
/ Felling a leaning tree to the side of the lean #13
LOL, once was asked to fell a birch that was threatening a client's roof.
I tied a good rope as high as possible and attached the other end to my 3/4 ton 4 x 4 in order to direct the fall.
I cut a proper notch , handed the saw to a helper and told him how and where to cut when I blew my horn.
Blew the horn, he completed the cut, tree fell and pulled my truck back and tree stopped when it hit the roof overhang.
LOL, I forgot to engage the 4 x 4! (and a PU is very light on rear end)
Fortunately the builder had used 2 x 6's under the facia so there was no roof damage.
(I'd used that method often and when properly done I have seen trees actually leap up and away.)
/ Felling a leaning tree to the side of the lean #14
A technique I have used on a leaner: Rig a guy or "preventer" against the lean and perpendicular to the intended direction of fall. Place the line as high as practicable to try to hold the mass of the top where it has the least leverage to fall away from the guy. Hopefully the line will be in tension and therefore controlling the tree during the entire fall.
/ Felling a leaning tree to the side of the lean #15
I have some 70-90 foot ash leaners. Unfortunately they are dead due to EAB.
For one, I took down a 90 footer next to it at an angle towards the leaner.
This pushed the leaner down a bit, and dropped some huge dead branches, so now I don't have to worry about those branches.
Leaner and other large branches now leaning over forested area.
I had a crew with a cherry picker come out to get the dead Ashes close to the house and garage, expensive, but either of those trees was big enough to do very significant damage at quite a few tons of wood.
Have a few more big ones to go and need to figure out what to do with so many widow makers high up.
/ Felling a leaning tree to the side of the lean #16
There are other methods and each has it place. In my case most trees are 16" and smaller and primarily white pine so boring is easy.
I also use various notch and boring angles to counter specific tree attitudes and crown configurations.
/ Felling a leaning tree to the side of the lean #17
I have some 70-90 foot ash leaners. Unfortunately they are dead due to EAB. <snip>
Leaner and other large branches now leaning over forested area. I had a crew with a cherry picker come out to get the dead Ashes close to the house and garage, <snip>
Ash decays fairly rapidly. If you have decade or so, those widow makers may likely fall on blustery days. Being in a forested area, the risk to life, limb, and property is considerably reduced. BUT, the longer you travel down the "let it rot" route, the more dangerous deliberate removal becomes. One of my "Oh S***" days was watching a dead tree fall 45ー from my intended direction when I was too inexperienced to recognize the hinge wood was unsound.
/ Felling a leaning tree to the side of the lean #18
And I just don't trust ropes to take any kind of strain.
With old technology ropes, you are correct to be untrusting, but there are ropes made with modern fibers that have unreal strength, wear resistance and low weight.
As an example, AMSTEEL-BLUE - Samson Rope. Dyneema is the name of the fiber. There are others brands and various grades with in brands as well. Some could be strong, some weaker, depends on what one needs.
Example:
1/4 inch galvanized wire rope has a breaking strength around 7,000 pounds and will weigh in around 11 pounds per 100 feet.
Amsteel Blue 1/4 inch rope has an average breaking strength of 8,600 pounds, with a minimum of 7,700 pounds, and have a weight of 1.6 pounds per 100 feet.
Later,
Dan
/ Felling a leaning tree to the side of the lean #19
Thanks s219,
I have been working on a group of five White Pine which are about 80 feet tall. So far I have dropped three, but the last two are leaning toward the house with a lot of top growth that way also. I may chicken out and hire the pros to do them.
Cheers,
Mike
View attachment 682475CONFIG]682472[/ATTACH]View attachment 682473View attachment 682474
I've been running saws and falling trees since 1968. Only once did I try a "hazard tree" (one that will do serious damage) Large Black locust about 30" butt diameter, slight lean oveer a trailer house (occupied). Rigged to cable from anchor to pulley about 15" up the trunk and back to and anchor tree gives a 2 to one mechanical advantage. Loose end of cable to my comealong which works from come-along to a pullet with hook attached to the cable from the tree. Anohter 2 to 1 which combinded gave a 4-1 pull on the tree, cable from truck to pulley on achor to the comealong. Did my normal felling cuts to pull it 180 degree from lean. First attempt at pulling it only gained a minor amount, mostly slack in the rigging. Cranked on come-along, pull - nothing, deepen cut, pull - nothing except gain a little on the come a long each pull. Finally asked the people to leave the trailer house as i was sweating blood over a total failue.
They refused. Repeat the deepen cut, pull, crank on come along, pull. It finally went where I plannedf but I worked on that thing for at least a half hour. Never again.
I have also called pros to take down 3 trees so far around my house.
/ Felling a leaning tree to the side of the lean #20
Mosst people rigging to pull a tree forget that onece it starts to fall the pull is gone as the pull vehicle isn't fast enough to keep the slack out of the cable.
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2016 Chrysler Town and Country Van (A59231)
2016 Chrysler Town...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
