FEL, TORO Groundsmaster Put Together
/ FEL, TORO Groundsmaster Put Together
Used the box blade in float today to spread some dirt:
Used the box blade to push the last of the dirt pile into the bucket on the V417:
/ FEL, TORO Groundsmaster Put Together #103
I really enjoyed reading this thread. @Xfaxman Thanks for doing this writeup. Nice work.
Used the 4' box blade on the TORO+Loader to put the raked out hay from the storage barn, into the 6' bucket on the V417:
First push:
Backed up to get the picture:
Moved over and lined up:
Second push:
Pushed what was left on each side to the center:
Final push into the bucket:
Job well done,
/ FEL, TORO Groundsmaster Put Together #110
Yep, once something hits the go pedal linkage under there, there is no stopping forward movement. You can't push hard enough on the reverse part of the pedal. Turning off the key is all you can do.
Here is the description that is with the picture:
Poor original design, should have done opposite.
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
Pallet Shelving (A60463)
Pallet Shelving...
2014 F-150 STX (A56438)
2014 F-150 STX...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
