FEL, TORO Groundsmaster Put Together
   / FEL, TORO Groundsmaster Put Together #121
How would you compare the stability of using the Toro as the tractor with this loader setup compared to a compact utility tractor?
Now that you have the V417, what do you still like about having the Toro loader setup?
It's sort of like you built your own Power-Trac type machine.
The Toro is much more stable than a CUT because the front axle does not pivot.
The rear axle pivots and steers.
The Toro loader is two feet narrower than the V417 so it is handy for working in the woods.
It would get used a lot more if I had a grapple for it.
403 (A52706)
403 (A52706)
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
