FEL, TORO Groundsmaster Put Together
/ FEL, TORO Groundsmaster Put Together #121
How would you compare the stability of using the Toro as the tractor with this loader setup compared to a compact utility tractor?
Now that you have the V417, what do you still like about having the Toro loader setup?
It's sort of like you built your own Power-Trac type machine.
The Toro is much more stable than a CUT because the front axle does not pivot.
The rear axle pivots and steers.
The Toro loader is two feet narrower than the V417 so it is handy for working in the woods.
It would get used a lot more if I had a grapple for it.
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
T/A Flatbed Tag Tailer (A64556)
T/A Flatbed Tag...
Cattle Feeder (A65640)
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
