Seat Safety Switch - SOLUTION
/ Seat Safety Switch - SOLUTION #1
kenlip
NSW Australia
Kubota MX5100 with Challenge FEL and 4:1
I was loath to permanently disable the safety switch, but definitely need a way to stand while using the forks and when hitching the FEL implements. Trying to press down on the seat with one knee while trying to control the hydrostatic pedal with the other foot was not fun. So, in desperation I came up with this hack and it has been working perfectly.
A slight improvement might be to add a tennis ball or similar to the centre of the bungee, so that when one sits down one is given a definite reminder that the safety switch is not engaged.
/ Seat Safety Switch - SOLUTION #2
or.....unplug the safety switch under the seat and then jump the two sides if the female plug to override the switch.
I had to do that because my seat would freeze in the winter and the safety sensor could not “feel” me in the seat, so it would stall out as soon as i put it in gear
/ Seat Safety Switch - SOLUTION #3
I did that about 8 years ago, the day after I bought it. It seems safer than some of the other workarounds. When I'm using forks I may have to stand up for an instant to see better and it seems silly to put your knee on the seat.
I opted against the jumper idea because it permanently disables the safety feature. I am a novice when it comes to tractors, so I would prefer to keep the safety switch active for general tractor use.
Freezing is not a problem in the Hunter Valley, north of Sydney. We have to worry more about the 42C/108F kind of days :)
/ Seat Safety Switch - SOLUTION #5
Can just plug it in normally anytime you want; I do that (pull the jumper wire out and plug the male plug in) if i loan the tractor to neighbors.
/ Seat Safety Switch - SOLUTION #6
The seat safety switch on my massey is a little block with a lever that the seat pushed down. I just ziptie the lever in the down position when I'm using the tractor for anything other than mowing. When mowing, I want that safety switch to be working.
/ Seat Safety Switch - SOLUTION #7
Here's what I came up with on my John Deere 4410. I've used it for a while now and I like what I did. Basically what I did was repurpose a toaster oven timer switch to bypass the seat switch. I can either switch it to permanently on or use the timer feature to let the tractor revert to factory setup after a set number of minutes. When the switch is in the off position the safety switches work as John Deere designed them.
https://www.tractorbynet.com/forums/safety/429362-pass-seat-safety-switch-pros.html?highlight=
That would be a lot of hassle for me. For example, I might want to pick up a pallet with the forks. For that, I want to be able to stand so that I can see the tips of the forks, so I need the safety switch deactivated. Once I have the pallet on the forks, I want to carry it a few hundred metres over some sloping terrain. For that, I want the safety switch activated. Jumping on and off the tractor to put on a cable tie and cut off the table tie would be a major pain in the neck.
I simply pull the bungee over the backrest for the times I need to stand and slip it off again once I want to drive the tractor seated. It is permanently attached to the tractor, so it takes about one or two seconds to slip it on or slip it off.
Excellent idea!!!
/ Seat Safety Switch - SOLUTION #10
On my Kubota L4400, I raised the seat. Looked at the switch, it is controlled by a nylon lever. I zip tied the lever down. done. If I want to remove it, just cut the zip tie.
/ Seat Safety Switch - SOLUTION #11
Nice simple solution :thumbsup:
/ Seat Safety Switch - SOLUTION #12
This situation is most irritating. My brand new JD 570 lawn mower will shut down the blades if I stand up or get off the mower. No buzzer and the engine remains running. My Kubota M6040 will buzz for ten seconds or so if I stand up or get off the tractor. After ten seconds the buzzer stops. Nothing has shut down, nothing has turned off. I've been appropriately warned and I continue on with whatever I am doing.
This dramatic difference must be due to some noxious government regulations.
I would be REALLY UPSET if the tractor turned off or the PTO shut down - every time I stood up and/or got off.
On my tractor, if there is noone in the seat, the engine stops. My understanding has been that this is to try to protect the driver from being run over by the tractor wheel or by an implement, in the event of him or her falling off the tractor.
However, if one tips the seat over forwards, the engine doesn't stop and the PTO remains active. In other words, it takes a definite and considered activity to put the tractor into that mode.
/ Seat Safety Switch - SOLUTION #14
On my Kubota just tipping the seat up isn't enough. You also have to set the parking brake. It would be nice if they included a temporary override button. Push it and get a few minutes without worrying about the engine shutting off.
/ Seat Safety Switch - SOLUTION #15
I get that stall situation when standing to see where a grapple is grabbing or leaning far enough to the side to line up SSQA.
One option I've pondered is to wire a step-on switch/mat in parallel with the seat switch so that either one would keep the tractor running.
Placing it on the footboard would require the same operator presence as the seat switch.
/ Seat Safety Switch - SOLUTION #16
OK, perhaps a simple enough solution to consider.
Splice in a pair of wires to parallel the circuit and wire to a suitably located switch that is key activated if you want ultimate safety.
Otherwise a simple 'on/off' would do for those annoying occasions that require your butt off the seat.
You would then have it both ways.
/ Seat Safety Switch - SOLUTION #17
How about a switch like on a boat that is tethered to you and kills the tractor if you get thrown ?
/ Seat Safety Switch - SOLUTION #19
The first day that I got my tractor home I wanted to use the backhoe. It's rather difficult to sit in the drivers seat and BH seat at the same time so I wired the safety switch down temporarily. That was over 2 years ago and I haven't changed it yet. I normally wear my seat belt so the chances of getting thrown off are low.
24in pin on excavator tooth bucket (A61307)
24in pin on...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2011 INTERNATIONAL PROSTAR SLEEPER (A60736)
2011 INTERNATIONAL...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2014 Dodge Ram 4500 Versalift Bucket Truck (A60352)
2014 Dodge Ram...
