What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,581
Here's how I upgraded mine. The pad eye is used when hauling it. I hook a big shackle to the pad eye and run the front chain thru it.
That’s pretty close to what I’ve planned for mine- I’ve got the expanded mesh sheet in the shop waiting for me to plasma cut it to shape.
Like the pad eye-think I might add that to the mod.
   / What did you do on or to your LS Tractor today? #1,582
Removed yet another freakishly large creosote bush...
   / What did you do on or to your LS Tractor today? #1,583
Finally finished making brackets and installed some LED lights. I made the brackets with the same spacing front and rear so the same light bar could be installed in front if I decide the 2 work lights aren't adequate.
   / What did you do on or to your LS Tractor today? #1,584
   / What did you do on or to your LS Tractor today? #1,585
Attempted to remove a small tree stump. I just made a mess sinking my tires in this darn Virginia mud. I think we are up to 3rd place for the wettest year on record in Virginia.
   / What did you do on or to your LS Tractor today? #1,586
   / What did you do on or to your LS Tractor today? #1,588
Nice job on the lights.
I liked my Tuff Top canopy for my Kioti.
   / What did you do on or to your LS Tractor today? #1,589
You値l want the grapple first-it makes chipping a much easier task. Pile the brush and limbs up with the grapple-switch over to the chipper at the pile and go to town!
A grapple would be a nice addition, but, so far I have been able to drive my chipper close enough to my brush plies to not really need one. About 5 hours on the WoodMaxx MX-9900 now and couldn't be happier! When I first moved in with my wife to be, (and the one who owned the acreage) she said that whatever I do, "don't by crappy tools. Only get quality tools or you will regret it in the long run!" Being a natural cheapskate it took a few purchases to learn this lesson, but, then it finally sunk in. With acreage, you are really taking care of things on a commercial level, and so your tools need to be up to the task. The WoodMaxx MX-9900 definitely meets the criteria.
   / What did you do on or to your LS Tractor today? #1,590
Nice job on brackets! I do hope you don't have the flying bugs like we do because with the lights under the canopy I had on my mitsubishi I had to change it just spent too much time with face full of them! I also would suggest if planning to use backhoe at night mount lights on the backhoe use trailer plug between tractor and backhoe to disconnect! I find with lights behind me on backhoe that I can't see down in the hole because of shadows!
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
