LS MT125 Rough Cold Start - Glow Plug Issue?
/ LS MT125 Rough Cold Start - Glow Plug Issue? #1
mslisaj
Gold Member
Klamath Falls, Oregon
LS MT125 Loader/Backhoe John Deere Sabre Lawn tractor w/Snow Blade
This is the third winter with my MT125 and we've had some cold mornings lately. A couple of weeks ago I did my usual first/cold start procedure - glow plugs for about 8 seconds and fire it up. This one morning I thought the engine was literally going to jump out of the chassis. It hammered and banged and carried on like it was going to throw a rod. Finally after about 30 seconds it smoothed out and ran just fine. I immediately thought "I didn't put in the winter fuel additive" and while it was warming up I treated the fuel. Well I'm not too sure this made a big difference but I don't remember this engine running so extremely rough initially cold on the first start of the day. It does fire right up without hesitation though but it makes me think that maybe a single glow plug has died and there is a dead cylinder for this initial run period. I don't have a dealer close by to ask about this so I come to the experts here. Upon going through this with the starts lately I realized that most of the banging noise is coming from hood and engine cowl as I can apply pressure to those components with my hands and all the angry noise goes away but the engine sure runs rough for this first 20 - 30 seconds; and rougher then I usually remembered it.
Any thoughts?
/ LS MT125 Rough Cold Start - Glow Plug Issue? #2
You can disconnect the wires from the glow plugs and measure their individual resistances. Bear in mind that with the low resistance of a glow plug you should note the resistance of the meter leads, too. Of course if one of the glow plugs reads open you've found your culprit. You could also check the voltage at each glow plug when they're activated. If you have a defective lead one may not be getting power. Glow plugs don't normally get "weak". They're a heating element usually being good or bad.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #3
Any thoughts?
I do 10-15 seconds on a 40 degree morning, longer if colder. Under 20 degrees, I might go 30 seconds IF I decide to go outside that day, which I often don't.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #4
Just out of curiosity, does this tractor not employ a timer for the glow plugs? My R3039H does. You turn the key on, wait for the glow plug light on the dash to go out (there is also an audible click from the associated relay). Once the light goes out, move the key switch to start.
Since this is a new development, I'd do an open test as described above and go from there.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #5
I cycle the glow plugs twice when it's cold out, much better!
Okay gentlemen, thank you all for taking your time to help out with your suggestions or ideas. I'll try and address all of you here. On the gentleman that asked if there was a timer the answer is no. You turn the key to the left, heat the plugs and then to the right to start.
For the gentleman that suggested a test procedure I will check that out as while I have been a mechanic all my professional life I have no real diesel experience. I of course understand their function and operation and the glow plug test is a good one and I'll address that.
Now to the gentleman that holds his plugs on longer depending on how cold it is, it's been awhile since I have had my owners manual out but I think it recommended something like 8 seconds. But the 10 seconds sounds resonable and on a 40 degree morning I don't really have an issue. But this machine has been cold soaked down to 15 degrees lately and maybe the 8 second on time is just not enough. I'll give a longer on time and report back.
Again as I mentioned I don't have a lot of experience operating a diesel engine and I get what the glow plugs do but I have been hesitant to hold them on longer fearing damage. But it's certainly easy enough to try and I'll report back.
Again gentlemen thank you for your time and wish me luck!
Lisa
/ LS MT125 Rough Cold Start - Glow Plug Issue? #7
At 15 degrees, I stay inside and sip on coffee or something similar. If it was life and death to go outside and do tractor stuff, I might do 15 on, 5 off, 15 on, start.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #8
Hi Lisa... been a while... Anyway, you just need to hold the plugs on longer... when I had my 125, I would do at least 25-30 seconds when it is that cold!
It will still be a little rough, but not like you described. I really believe that is your only problem.... just didn't get them hot enough initially.
My son has an 'old school' Cummins diesel in his truck.... no glow plugs.... the other morning it was around 12 degrees overnight. When he started it up in the morning, I thought an old steam engine was coming down the drive.... CHUUGG.....CHUUGG...CHUG..CHUG..CHUG. Then it took 20 minutes to barely move the needle off cold.
Well I think you guys are on to something. I just got down my owners manual and it says for "cold" starting 4 seconds. I agree that's not enough so I was doing 8 seconds which was not enough. Now last evening it was about 35 in the shop and I went out there and heald the glow plugs on for 20 seconds and it fired right up and ran relatively smooth. Last night it got down to 25 and I just tried to start it with a 25 second on time and it started and hammered around a little bit but it was better. Next I'm going to try the 15 on 5 off and 15 on and start. After seeing it work last night I think this is the key. I'll keep you guys in the loop on what I discover and it's funny the book only says 4 seconds.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #10
I'd bet the manual means just at room temp 'cold'. I'm thinking of adding a manual switch to the relay on two machines. The CUT only has glow when cranking. :( The Mechron switches plugs off too soon and a coolant temp cutout makes it hard to start after a brief shutdown ... esp in 'seasonably cold' temps.
I throw blankets over my 'good', indoor-kept tractor and put an electric heater under it for an hour before starting when below 20ー. Below 15ー I don't start CUTs. It takes too long to warm up the hydraulic oil anyway.
Thanks "the old grind" for your thoughts and comments here. I'll bet your absolutely right with the manual's instructions are for if it got down to a cold 50 degrees F. The only real time I use this tractor is in the winter and your comment about not being able to truly warm it up is so true. But I'm pushing and moviing snow with it. I'm learning a longer glow plug cycle time truly makes a huge difference.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #12
I put one of these in-line coolant heaters in with a timer on the extension cord. I only plug it in if I think I will use the tractor the next morning.
https://www.amazon.com/Kats-16800-L...=inline+coolant+heater&qid=1608384545&sr=8-11
Great idea on the hose heater!
Just went out after a 25 degree night and I held the glow plugs for 30 seconds and it started and ran like it was all warmed up. So I think that was an easy fix. But thank you all for your help, now I know how to test and replace glowplugs if I have to that one day.
Regards,
Lisa
/ LS MT125 Rough Cold Start - Glow Plug Issue? #15
Amazon.com: Kat's (168) 2" Lower Radiator Heater Hose: Automotive
My dealer installed the Lower Radiator Hose Heater before he delivered my tractor. I plug the heater in for 1 hour before starting and you'd think it was 80 degrees outside. Oil pressure pops right up and there is no engine rattle. Heating any engine before starting helps increase its lifespan. Plugging in is recommended any time temps drop to 20F or colder.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #16
Yeah, I gotta have that, say three of 'em to start and a fourth if I can get the skidder to start in ANY weather. :rolleyes:
/ LS MT125 Rough Cold Start - Glow Plug Issue? #17
My old plow truck has a 7.3 Diesel with dual batteries and glow plugs. I added a trickle charger to keep the batteries fully charged, a block heater to warm the engine, and pad heaters on both the oil and transmission pans. Even with all this, it takes at least an hour with everything plugged in for this beast to fire up.
These SCUTS and CUTS have small engines but they would still benefit from ANY additional heat.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #18
Doofy, even with a trickle charger to top up, if we're plugged into 110v anyway there are thermostatic battery-heating 'mats', too. They can work wonders. ;)
Note that a typical CUT 'calls out' a battery with 80% or more of the CA/CCA of a 'road' diesel of twice the displacement/hp. :eek:
I keep a 3-bank of spare batts rotated between a 'desulphating' trickle-charger (Battey-Minder 1500s aplenty) and have dual batts in my trucks. (Chev 2500, Ford SD-450, I wish both had battery isolators vs the direct connection on the Chevy.)
btw, no need to disconnect some higher-amp 'automatic' chargers when cranking. :2cents: I have a 10a Exide that's a lifesaver.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #19
I've used 80 watt Battery Blankets for years and I'm not sure why I stopped using them. Maybe I'll start using them again. They really help with cold weather starts and also prolong the life of the batteries.
/ LS MT125 Rough Cold Start - Glow Plug Issue? #20
'Wet cel' battery lifespan is directly proportional to time spent 'topped up' to full charge. No exceptions, although SLA and gel batteries have a lower rate of self-discharge when idle and typically a longer life. They still go to s__ if left discharged for any length of time, weeks-months for example.
I check my traps in the barn and rotate chargers/tricklers daily between several machines that may be used only once or twice/yr, having learned a lot during my biking and boating years. :laughing:
Has compression. Unknown operating condition. (A64553)
Has compression...
CAT 330DL Excavator Grapple (A68134)
CAT 330DL...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
