3 point hitch quick connect
/ 3 point hitch quick connect #1
Engine Mike
Member
Rochester hills michigan
Kubota B2320
I am still looking for a 3 point hitch quick connect for my Kubota B2320. Wow the Harbor Freight quick connect looks awesome and for $110 minus 15% seems like a great value. Best I have found on other brands and models is around $350. Of course the price does not matter if the hardware does not work. Does anyone have any experience with the Harbor Freight quick connect either good or bad. Would appreciate any experience. The customer reviews on the Harbor Freight website are good but could be staged of course.
/ 3 point hitch quick connect #2
Works good on my Yanmar, should work on the NH I have. Still need to modify a couple implements to work with it, that would have to be with most any quick hitch.
/ 3 point hitch quick connect #3
Its a great price, and I think it will work out just fine. Just make sure your implements are properly configured for this Quick Hitch. I have found after 3 years experience, some implements are just not acceptable to a QH, despite the manufacturer advertising and saying it is. Right now I have switched to Pats QH, which is really quick for the two lower lift arm connections, and I still manually connect the top link in the normal way. Ultimately I found this is best for me.
For implement usage, for example my Post Hole Digger is almost impossible to use a QH due to design of the implement. Also pin orientation and placement may need adjustment on most implements. The easiest for QH are my BoxBlade, landscape rakes, rotary and flail mowers and tillers. So after you get the QH, check that first day which of your implements may need adjustment. One other thing, the HF quick hitch is both Cat1/Cat2 ready.
/ 3 point hitch quick connect #4
Buy my HFT QH for $75. Used <1/2 day. Pick it up on your way to or back from Bronner's. ;)
I have too many bits that aren't ASAE spec and that need unique top link configs because of that.
I also have to hook up the PTO for tiller or flail mower anyway. Pat's Easy Change suits my needs/uses well.
/ 3 point hitch quick connect #5
I've been using the HF QH for almost 10 years. Works great for me. The biggest problem you may run into is the adjustable hook bolts may interfere with some implements that have narrow upper pin connections. This issue exists with all the QH units that have adjustable hooks. This can be resolved with the simple top hook link or permanently by changing to flush pins like I did.
/ 3 point hitch quick connect #6
After reading many threads, I decided a QH was not a good fit as I have older implements that would have to be modified and I am not good at that. Then, with a rear snow blower, I have enough trouble hooking up the PTO without more stuff in the way.
I nearly pulled the trigger on a Pat's QH when there was sale a while ago on this forum. It seems like a decent compromise but waited too long. It is not as easy as the "real" QH's but more forgiving wrt what will fit and does not add more stuff at the back to deal with.
I am now looking at this:
Welcome to CARTER AND SON'S TOOL AND DIE
It seems simple and affordable but not much information on it so I wonder how well users like it.
/ 3 point hitch quick connect #7
Does it matter that much if it's not on sale? :D
I was all set to buy another PEC, but missed the special offer too.
I can't afford another one at full price in times like these. :rolleyes:
/ 3 point hitch quick connect #9
Q
Not much, but once the blower is hooked up, it stays on until April so no hurry. Still wondering if the Carter is a better option
/ 3 point hitch quick connect #10
I initially bought a HF quick hitch and took it back for reasons mentioned above...the top hook needed rigged to make it work...
I bought a Pat’s system and never looked back! It works well with all my attachments (brush hog, land plane, ballast box, rear blade). I did, however, have to buy a longer top link (Tractor supply $50)....
/ 3 point hitch quick connect #11
I have the HF hitch and have used it fir 7 years. Mine was 79.00 with the 20% off cupon. Most of my attachements are from the 60's or before and all I had to do modify the top link hookup. I had the same problem as was mentioned with the bolts on th adjustable top hookon the hitch si I extended this hook out farther by drill 2 holes in a 1 inch square piece and welding it to the hook. Works like achamp now. No matter what buy you will have to modify the attachment shmehow
/ 3 point hitch quick connect #12
Great post. I wish i had seen those before i bought a QH, i might have went that route. But i ended up with a Land Pride QH05 for our BX23s for $230 OTD this past year after an exhaustive research for 2yrs. Luckily, every implement i have, fits perfectly fine with the LP QH05. But this type system you posted, sure is alot cheaper dollar wise. Surely not as convenient as what i have right now, but this is likely a great set up for those that dont have the extra money to throw at a QH to attach implements. I looked at the HF QH a few times, watched some YT reviews, i walked away. I dont want to buy something that i have to modify.
I`m plenty happy with our LP QH, i dont have to get off the tractor to hook or unhook anything, unless i have to hook up a PTO shaft, but you`ll have to do that with no matter what system you have. So far, i dont own anything that has a PTO shaft to hook up, yet. Time is money for me, the LP QH saves me time, big time. It all comes down to what works best for each person - everybody`s needs are always going to be different. For me, due to spine damage like i have, the less i have to do, the better it is for me. Climbing on/off/on the tractor is hard on me. Then when having to muscle around implements on/off/on/off, what i have now is a god send, for me. Yes, i paid a bit more to have a QH option, but my body thanks me everytime i change implements. Getting old, having bad spine injuries, its not for sissies, thats for sure.
One thing i would like to add, those PAT`s style systems, you still have to align the arms to the implement. You`ll still have to attach the top link. A QH is the best way to go, if it will fit all your implements.
/ 3 point hitch quick connect #13
I'm another satisfied Pat's Quick Hitch user. I had to modify no equipment. I did need a longer drive shaft for my mower but I learned the old one had been too short all along and probably unsafe when the dealer installed it. I slso needed a longer top link as Pat's sets the whole implement back about two inches. The angle of the hitch on the lift arms may need adjusted a bit for different width implements to keep everything square but that's quick and easy to do.
/ 3 point hitch quick connect #14
I have a Pat's and find it much easier to use than just the lift arms. I did find that the height of the outside end of the hook was too tall for my King Cutter mower. There is a box frame just below the pins on the outside, so I flipped the pins inside the upright frame and it works that way. Because of that experience however, I look at the Carter and wonder how often that would happen with this one. It sits on top of the arms and must require 6-7 inches of clearance. The Pat's might require more like 4-5 inches. Check out your implements before you buy.
/ 3 point hitch quick connect #15
/ 3 point hitch quick connect #16
/ 3 point hitch quick connect #17
Those who want a QH for a BX series tractor, make sure you are checking the weight of these QH`s. Some are pretty heavy.
Weight of things you bolt on and hook up to the BX needs to be considered and factored in.
The harbor freight QH (for instance) weighs 62lbs. The Land Pride QH05 weighs 37lbs.
That don`t seem like much of a difference, but it is when you have a tiny tractor that is already limited.
My dealer also threw in the floating top link kit, he says they come with the QH05 automatically, some dealers call it an optional item and charge you extra for it.
/ 3 point hitch quick connect #18
Tried the Pat’s on my BX, still had to get off tractor to adjust width (even with the bar)). When I got my L3901, I went for the LP QH15. It just works, no modifications (has adjustable top hook). After the time saved, I bought another LP QH15 for my MX5200 (sometimes using both tractors at one time-with wife). Only issue is that you have to get the bushings to convert (CAT1 to CAT3). Once I got them all situated, It takes a hot minute to hook up any of my implements to either tractor. My time is worth the expense and aggravation.
And just to add....I also use the PTO quick connect from https://tractorptolink.com/. Saves my sanity from erosion.
Love the forum, lover the ideas here.
Thanks,
Steve
/ 3 point hitch quick connect #19
Tried the Patç—´ on my BX, still had to get off tractor to adjust width (even with the bar)). When I got my L3901, I went for the LP QH15. It just works, no modifications (has adjustable top hook). After the time saved, I bought another LP QH15 for my MX5200 (sometimes using both tractors at one time-with wife). Only issue is that you have to get the bushings to convert (CAT1 to CAT3). Once I got them all situated, It takes a hot minute to hook up any of my implements to either tractor. My time is worth the expense and aggravation.
Thanks,
Steve
Steve, i agree with you 100% about the Pat`s design. I looked into them and said NOPE, more hassle than its worth, to me, for something that is almost aready $200 and i still have to get off the tractor to set them up! I`ve seen a couple people that used in my neighborhood, the Pat`s design didnt seem to save that much time due to having to get off the tractor and align things up just to hook up implements. That`s when i said to heck with it and just bought the Land Pride QH for our BX23s for $230 OTD and needed nothing extra, no messing around to make it work. Seconds to change out implements with the LP QH, and without ever getting off the tractor. (who wouldn`t love that!) I dont have any rear PTO driven implements, so this LP QH works super great and super quick. I couldn`t be happier. I`m much older now and i just can`t fight with heavy things like i use to when i was alot younger. Even my wife can change out all of our implements on the fly with it. And thats sayin somethin right there when SHE can do it by herself without, me...lol. Dont tell her i said that though, because she`d drag me around the property with the tractor if she knew i said that...lol.
/ 3 point hitch quick connect #20
Pat's doesn't save me getting off the tractor to connect. It does save me time and makes it a one man job. I wouldn't trade it.
That said, the 1-piece QAs let you adjust your stabilizers 'once and done'. With chain/turnbuckle stabilizers to futz with that can be a real time-saver.
I have one tractor with extendable draft arms and the square tubular stabs with pins. That's still my favorite setup.
btw, Being able to leave whichever attachment on each tractor and hopping from seat to seat is almost cheating. :D
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
60in. Work Bench (A65640)
60in. Work Bench...
