1715 Hood Prop Arm
/ 1715 Hood Prop Arm #1
Dataway
Gold Member
Greenfield TN
Ford 1715, BX2200
My 1715 has a notched arm and spring setup to prop up the hood. Connects to a bolt down by the radiator area. Trying to find it on the parts diagrams and I see nothing even close. Certainly does not appear to be something someone added since there are factory provisions for it on the hood.
Do you 1715 owners have this hood prop?
I wanted to get a new bolt for it ... looks like it should have a shoulder bolt but just has a conventional bolt instead ... so it keeps coming loose as it can't be tightened down or the prop rod won't slide in it.
Thanks.
/ 1715 Hood Prop Arm #3
Thanks.
Sounds different than my 1920.
/ 1715 Hood Prop Arm #5
Just use a little BLUE loctite that will keep it from vibrating out.....
I was thinking about that ... or just turning up a spacer and using loctite too. Now I'm just more curious than anything else, as to why it's not shown in the diagrams.
Here is a photo of the mystery hood prop. Attached to a bracket that was obviously an OEM part of the hood.
/ 1715 Hood Prop Arm #9
I have the same hood prop on a 93 F1715. Ive been having some of my own issues with it only mine is electrical. Occasionally when I open or close the hood while its running there will be sparks between the bolt on the radiator frame and the sliding prop. I also have some starting trouble and suspect they're likely related.
/ 1715 Hood Prop Arm #10
WOW sparks that's not good... Hope you leave the tractor parked outside..........
/ 1715 Hood Prop Arm #11
I keep the battery disconnected. Anyway thats the little problem that brought me to this forum.
/ 1715 Hood Prop Arm #12
You should start your own thread with pictures , Might get more help......:)
That's the same prop arm that's on my NH1920. It looks too short in the Messick's picture linked below but if you call them, they can give you the dimensions and specifics on the shoulder bolt. New Holland 192 - 4 CYL COMPACT TRACTOR 2 SERIES(1/87 - 4/2) Parts Diagrams
I bet that is the same one .... and I'll wager my hood was replaced some time before I got the tractor with the hood from a 1920. It was a rental unit from a dealership so it probably saw it's share of haphazard use. All the parts there look identical to what is on my 1715.
Thank you sir.
/ 1715 Hood Prop Arm #15
Thank you sir.
If you need me to, I will take my 1920 hood support arm bolt out and measure it for you.
Thanks fried, I only needed the shouldered anchor bolt. I'm good to go now.
2020 DODGE RAM 2500 (A67714)
2020 DODGE RAM...
Unused 2023 Maybridge B7D 6ft. Chain Harrow Tractor Attachment (A66734)
Unused 2023...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
