1715 Hood Prop Arm
   / 1715 Hood Prop Arm #11
I keep the battery disconnected. Anyway thats the little problem that brought me to this forum.
   / 1715 Hood Prop Arm #12
You should start your own thread with pictures , Might get more help......:)
That's the same prop arm that's on my NH1920. It looks too short in the Messick's picture linked below but if you call them, they can give you the dimensions and specifics on the shoulder bolt. New Holland 192 - 4 CYL COMPACT TRACTOR 2 SERIES(1/87 - 4/2) Parts Diagrams
I bet that is the same one .... and I'll wager my hood was replaced some time before I got the tractor with the hood from a 1920. It was a rental unit from a dealership so it probably saw it's share of haphazard use. All the parts there look identical to what is on my 1715.
Thank you sir.
   / 1715 Hood Prop Arm #15
Thank you sir.
If you need me to, I will take my 1920 hood support arm bolt out and measure it for you.
Thanks fried, I only needed the shouldered anchor bolt. I'm good to go now.
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2003 INGERSOLL RAND SD-105DX SMOOTH DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
Toro Reelmaster 5400-D Fairway Reel Mower (A55851)
Toro Reelmaster...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
JNC 1224 Jump Box with Charger (A54865)
JNC 1224 Jump Box...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
