Learning experience
/ Learning experience #1
Waffles
SLO, CA
MT225HE
I have a steep concrete driveway in front of my house. I always run the tractor in 2wd on it. Over the weekend I was loading a pallet in front of the house with the tractor up hill on the drive. I lifted the pallet and started down the drive aimed at the house. Hit a small bump in the concrete that started a slide. My first reaction was to add brakes thinking my increase in speed was just the steepness of the hill. By the time I figured out what was happening I was going too fast and too close to the house to drop the load. I was lucky to be able turn to flatter ground missing the house by a couple feet.
Lessons learned:
Need more ballast. I knew this already but I don't have a way.
Keep heavy side up hill, even if inconvenient.
Use 4wd with any heavy front load, better to be safe than worry about wear and damage to driveline.
I don't have an easy way to add weight to my BB.
/ Learning experience #5
Second on the filling of the rear tires.
Mine are filled. And after breaking my last tractor twice trying to lift more than it could handle.... I dont use rear weight for any reason.
I let the tractor tell me its too much.
Filling the tires is not as efficient as adding weight on 3PH. I need to be efficient because the HST struggles on my steep hills. I need to be able to easily add and remove ballast based on tasks.
/ Learning experience #7
That's just crazy advise.
Your loader manual should cover this. My LS manual says I need both. Tire ballast, liquid or steel weights, and a counterweight on the rear.
It does. I need to figure out how to add 500 pounds on top of my BB.
/ Learning experience #9
Hang some suitcase weights off it.......
/ Learning experience #11
X2 on the suitcase weights. Heavy hitch I think still is the cheapest place to get those.
Or maybe the OP can pickup a ballast box and use that instead of a box blade. Cheaper option if it can work for him.
/ Learning experience #12
I'm guessing the OP wants the BB on and ballast at the same time. In any case the filling of the tires while maybe not enough and as efficient as adding weight further back, does not take up real estate so I would take advantage of that 'storage' location and lessen the amount you need to scab on aft.
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
1761 (A58375)
1761 (A58375)
2004 John Deere 8320 (A63688)
2004 John Deere...
