Kioti CK2610SE Power
/ Kioti CK2610SE Power #1
CarbonBeggar
Spokane, WA
Still Shopping...
Hi all,
My wife and I just bought a new house on 10 acres and will now need a tractor to care for it. The property is mostly fenced pasture that will need to be mown by either a MMM or brush hog, but the far end has about 1.5-2 acres of forested area. There is also a dirt road/driveway that will need to be cared for and snow removal in the winter months.
I was looking at the new Kioti CK2610SE, which looks like a pretty good deal considering the premium features without the added cost of a premium name. The one concern I have is from a TTWT video (below) where he questions the machine.
Kioti, McCormick, & LS Cab Tractors! - YouTube
Tim brings up two concerns (at 04:13): resale value and horsepower. His rationale being that the 24.5 horsepower being too anemic or underpowered for a machine of it's size.
Which brings me to my question; what do you all think?
Is there enough "oomf" in the 2610SE to run A/C during 100 degree temps while pulling a 5ft brush hog behind it, or doing any of the other tasks it will be required to do? Or is it better to step up to the CK3510SE?
/ Kioti CK2610SE Power #2
I had the 2610 while waiting for my 3510, put on 18hrs, had no issues doing anything I wanted with it, and I'm sure it would do everything that you would want it to, however with ten acres I'm sure you would be happier with the 3510, these things are little work horses and you will find all sorts of things to do with them - for ten acres I'd most defiantly get the 3510, the 3510 would give you a little more power when needed allowing you to remain in a higher range, completing some tasks a little quicker.. I've not done a task the the 2610 could not have done, but I know the 3510 did it a little faster with less effort - if you can afford it and it's for a long term, go with the HP...
/ Kioti CK2610SE Power #3
I've lived on 40acres mowing 10+ acres with old 25+ and newer 40+ HP tractors... And I'm also currently shopping the Kioti CK series currently as well for a smaller place. I've driven and looked at the current Kioti's and looked at more Youtube videos than I care to admit as well. IMHO, get the CK3510 with a cab for mowing that much acreage. The CK2610 punches above it's weight for loader functions and dragging/pulling. It can also bush hog with a lighter weight 5' cutter. But the CK2610SE cab version is going to be under powered if you have a LOT of mowing in ROPS form as it sits... especially in a cab version if you have to really bush hog heavier stuff to tame with the A/C causing more parasitic loss to a few of those already little 26HPs along with the HST. On the other hand, if you are just mostly going to be running a finish mower on FLAT terrain and AFTER getting the place under control, you may be OK with only CK2610SE cab. The pricing I've gotten is only maybe $2500 more for the 35hp so go for it. Trading a tractor later you're not happy with is at least double that.
/ Kioti CK2610SE Power #4
I have a CK4220 here in Australia - same chassis size and with cab, but different engine configuration. Anyway, I run a 5¼ foot mulching mower on 25 acres of some pretty tough grassland (mostly African lovegrass). I'm very pleased with the physical size of the tractor as it lets me get into some tight spots for landscaping work - but I don’t think I would want a lower powered machine for the mowing, as the revs can drop in tough patches. If you have easier going, maybe the 26HP will be enough.
/ Kioti CK2610SE Power #5
Hi all,
Thanks foe the shout out.
Let me be clear that I don’t have experience with this unit, so my concerns are not from actual experience. Rather, experience with other machines of similar horsepower, even without a/c.
I hope to try one of these Kioti’s soon!
Tim
/ Kioti CK2610SE Power #6
Since looking at tractors in this size myself. The CK2610SE is competing directly with the popular B2650 and now LX2610 cabbed tractors. I agree more HP is always a benefit for the same frame sized tractor. The Kioti does have higher numbers over the Kubotas, so it isn't a one off tractor.
Wow! Sounds like I've got my answer. Thank you all very much for the responses, they've all been very helpful. It looks like we'll be opting for the 3510 and save ourselves the grief of wishing we'd bought just a little more machine.
I really appreciate this TBN forum. It's also really helped my wife feel comfortable with such a large investment, and to know that I'm not just getting "tractor greedy"- so a big thanks to y'all for that.
Oh and @TTWT- thanks for chiming in and please keep the videos coming!
Best,
CB
/ Kioti CK2610SE Power #8
I have been very happy with my CK3510SE on my 11 acres so far.
/ Kioti CK2610SE Power #9
Tim
I got to test one of these Kioti units with the same drivetrain (engine, transmission) as the CK2610 this week. I do think folks would appreciate the extra power offered by the 3510. The 25hp is enough to get the job done, but a few extra ponies would help!
I’ll publish a video on this eventually...
Tim
/ Kioti CK2610SE Power #10
I wouldn't turn a 5' BH with a tractor of <25 hp, esp with the AC running. An operator might be comfortable in a cab in 100^ weather but the engine will be working hard in the heat.
I never run any PTO attachments when temps get to the high 80s. BTDT, and oil consumption is noticeable. (flail, tiller, etc)
All that said, I've owned <25hp and ~35 hp CUTs that were/are otherwise identical. For anything but PTO work they perform all the same tasks with equal ease.
What Tim says above about extra ponies. :thumbsup:
btw, I could live without the cab, and enjoy operating at the 43rd parallel in our climate. But I'm only 70 and things could change as I get older. :)
/ Kioti CK2610SE Power #11
Cabs are expensive office space when ya think about it... ya get to buy more tractor on top of the cab expense. Ain't no school like [open station] old school. Wear a hat or a scarf.
/ Kioti CK2610SE Power #12
I have a ck4010 hst cab tractor. My brother in law has an open station ck2610 hst.
I wouldn’t want any less power, but find myself traction limited sometimes, so more power wouldn’t be helpful very often for my purposes.
My bil refered to his 2610 as a beast when he first got it, but last I talked to him he mentioned that more power would be useful while bush hogging. He cuts trails with a 5’ Kioti/Woods mower primarily, and uses forks and the loader some.
I blow snow and use the back blade, forks, and some bush hogging, but not much.
/ Kioti CK2610SE Power #13
I値l publish a video on this eventually...
Tim
Can you share which model you tested? Hoping the CX2510. I'm caught between that and the 2032/38r and would love to see a loader test on the CX2510 like you did on the 220R MSL recently. These tractors are surprisingly similar in features, size and weight but it's hard to know, really, what the loader will lift unless you're able to do tests like you've done recently. Thanks for those, BTW. Still kind of wish the 1025r's 120R MSL had as much relative increase in capacity as the 220R MSL has versus the NSL.
/ Kioti CK2610SE Power #14
Wow. I live just south of Dallas and most of what I do is bush hogging and some tilling. We have daytime highs above 90F beginning in April through October and consistently between mid May and mid September. Evening lows from June-August often only fall into the upper 70s. I do 90% of my work in temps between 85-105f. Now, I don稚 have to plow snow so there痴 that....
/ Kioti CK2610SE Power #15
I'd jump up the the DK cab series before I bought a CK cab.
I'm an open station guy though.
/ Kioti CK2610SE Power #16
The CK2610 is significantly bigger than the B and LX Kubota series. Much heavier and MUCH MUCH MORE lift capacity/hydraulic flow. It outlifts not only the B and LX serious, but also the L series as well by more than 500#. It is a strong tractor. I know of one that was checked on a dyno and got 24 hp at the pto in a test (although only rated 21.5 at the PTO according to specs stated by the factory), which suggests around 28 hp at the engine. If that is true, then they are reporting less than the tractor is actually producing...or that one was just a fluke. I don't know the legals of this, but regardless the engine is the same engine that was once used in their 35 hp tractors.
Additionally, if hp while bush hogging is a concern, get yourself a flail mower instead of a rotary cutter...and you will have all the hp you need. Some flails will cut 3" material with a 25 hp tractor.
I had a Woods BB60X and gave it to my brother in law after getting a flail mower. My CK2610 is open station but ran the rotary cutter fine...however, I just like the concept of the flail mower better...better cut, requires less hp, and you don't have a that super long attachment on the back that makes you always having to look reward to see where it is when turning around trees, fences, or buildings. Plus rotary cutters will sling rocks and such much further and harder than a flail mower.
/ Kioti CK2610SE Power #17
Best,
CB
Go with the CK2610 and avoid the DPF
/ Kioti CK2610SE Power #18
Tim
Love your videos Tim. Best tractor channel on YouTube IMO. If you were closer, I would buy you one of those cheeseburgers you talk about. haha. Which tractor did you test with the same drivetrain as the CK2610? I wasn't aware of the same drivetrain being offered in another tractor. Very similar ones for sure...but exactly the same?
The CK2610 has 100 CI displacement, but the CX2510 is only 87 CI
/ Kioti CK2610SE Power #19
From a recent CK2610 thread/post in 'Kioti Owning/Operating' regarding adjusting the injector pump rack limit:
There is a Facebook Group called: Kioti Tractor Tuning. One CK2610 owner commented on this subject.
"I adj. the fuel screw on the injection pump today and it made a huge difference! It woke the engine right up. The hardest part is getting the stupid cap off the adj. screw. I turned the screw out 2 full turns. I get little puff of black smoke when I throttle up. the engine throttles up faster and it doesn't bog down anymore when I'm in high gear."
/ Kioti CK2610SE Power #20
Yes, CX2510. Operated one day at NC State University.
Did not get to test loader lift capacity.
We did notice that, like other 25hp larger frame machines, it is sort of underpowered.
I liked the machine.
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A65643)
2006 W-W TRAILER...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
