425 front cover gasket blown
/ 425 front cover gasket blown #1
weathda
Alabama
Farmtrac 665DTC, Kubota L2550, John Deere 310SE, Dresser 175C
Was mulching leaves Saturday and coolant started blowing out of the front cover gasket near the right head water port. I have it apart. Anything else I need to replace while in there? Should I replace the plastic governor gear while I'm in it? Are those prone to break like the plastic cam gear? This is a 99 model so it has the steel cam gear.
/ 425 front cover gasket blown #2
Looks like you are doing well with the repair.. how does the water pump look?
/ 425 front cover gasket blown #3
I can see why that would happen. There is only one bolt near the gasket, there should be two, like there is for the exhaust. Poor design in my opinion.
I would wager that this is a common problem with this engine.
Richard
Looks good. No play in the propeller. The hardest part of this job so far has been enduring the smell of dog poo in the tires. I think I ran over every...well, you get my drift :)
Richard
Agreed. The very spot of the leak is was at the bottom of the port where it should have another bolt.
/ 425 front cover gasket blown #5
I do get your drift (pew!!).. have a neighbor with dog that knows just where our lot line is at, and he keeps their yard clean. Not mine!!
If I see the piles, I mow around them until they dry off. Don't think there is a more disgusting smell.. and that includes cow, pig, horse, sheep, chicken, etc. farm animals. Cat boxes are a close 2nd, but that doesn't end up stuck on the tires.
I had my 425 Kawasaki torn down a year ago, chasing the plastic gear, coming to find out it had already been changed. Apparently when the water pump went bad on this '66 engine.. If I remember right, it was Richard001 who saved my bacon when a picture I posted looked to him like it was steel. A magnet led me quick to the same conclusion.. so stopped tearing it down and re-assembled. Put a new water pump in, and now have what looks like a perfectly good water pump sitting on my bench.. needing a good home (free with shipping paid ;) ). Hate to throw it away.
Thanks for the offer on the water pump beenthere. Let me double check mine. I'm waiting on my gasket kit to come in and it's been in the 30s here the last day or so. Not too excited about getting back out to work on it in those temps. Glad this happened at the end of the season!
/ 425 front cover gasket blown #7
Yes the plastic governor gears can and do fail so would replace while you have the engine apart. What does the water pump look and feel like? 425 I fixed it was pretty sloppy on the bearings so replaced it while tore apart. From memory when the water pump fails they can leak into the oil Vs external.
I went out tonight and double checked the play on the water pump propeller and gear. It's nice and tight. I'll just throw it back on.
Thanks for confirmation on the governor gear. It looks awfully discolored from the oil. They're cheap enough, I'll plan to replace it.
It's always something with this mower. I bought it used about 3 years ago and it was tired when I bought it. I keep saying if I can get one more season out of it.
/ 425 front cover gasket blown #9
Being you're able and can work on it, I don't know that I would want to write it off for some of the newer machines.
Yeah, I think that's why the widow lady who owned this sold it. It was nickle and diming her to the point she was just going to hire a mower.
The power steering and all wheel steer is nice! My mouth is watering for a 72" zero turn, but I just can't stand to spend the money on what they cost. Figure I'll keep throwing a few bucks at this mower if the deck will last - that seems to be the weakest link. Either way, I'm planning to keep the 425 even if I get something else. It'll make a good spare and give something my boys can use to help with mowing duties.
/ 425 front cover gasket blown #11
Before you reassemble the water pump manifold, after removing any gasket material, check to see if the mating surfaces are flat.
The simplest way to do this is to take a flat steel or Al plate, tape a piece of sandpaper on it and rub the manifold over it a few times. If the surfaces are flat, the entire mating surface will show some marks from the sandpaper. If not, then more rubbing will correct the surface and make it flat and true.
Now looking at the manifold photo, there maybe a problem with the pump gear and prevent you from doing what I just described. The next best thing I can think of is using a straightedge and a feeler gage. If the pump manifold surfaces are more that a few thousands of an inch from being flat and true, you need to fix it.
Richard
I'll put a straight edge and feeler gauge on it to check it. Thanks.
Also, how does the governor drive gear come off the case? The service manual doesn't really describe the removal - that I can find. All I see is a thrust washer behind the gear. Does it just press on and pull off? It seems like it's in good condition, but I ordered a new one.
Figured I'd post an update. What I thought would be a straight forward job has turned into a bit of winter project. I started not to post this, but maybe you can learn from my mistakes.
Got the new governor gear installed, new internal oil orings, new crank seal, installed cover,pump, and put back together. Had no issues. Almost home free.
Mistake #1. In my haste, I didn't clean the three skinny 6mm water pump bolts which were going in a bit tight. Looked like they had a bit of corrosion on them. The last one I was tightening down snapped off in the block.
I could not fathom tearing this thing back apart just because that little stud broke. Should've stepped away and let everything sink in.
Mistake #2. In a haze, in my panic and figuring rather than pull everything off that I had just installed, I ran a left handed drill bit in to try and drill the stud out. Should've just removed everything and could probably have extracted the bolt with some vice grips or an easy out. Anyway, the drill got off into the aluminum block and cover which is super soft. I ended up tearing the gasket, eating into the side of the block. I made everything worse and still had to take everything off.
Anyway, I surveyed my drilled holes. Tapped the holes I'd drilled and inserted studs with locktite sealant and then cut the studs off. Kinda like block stitching. Drilled the stud bolt hole.
Mistake #3 Started tapping the hole for the pump bolt with a 1/4" tap and the tap broke off in the block. I think it was digging into part of the old 6mm bolt stud. The long skinny tap flexed just enough that it snapped. Sick again.
I go to the auto parts store and buy some high temp JB Weld. Packed all the crevises and stud passage with weld. Sanded flush to just create flat sealing surface.
Luckily the 620D has a two threaded holes on top of the block just above this water pump bolt that broke. I figured maybe I could make a bracket that will allow me to tighten down the cover.
Order gasket kit #2. New seals, orings, and crank seal going in again.
On the upside, I did fix the broken dip stick tube bracket.
/ 425 front cover gasket blown #14
I guess it's the old "live and learn" technique.
Next time you have an issue with getting bolts out, use some penetrating oil. When putting bolts back in, especially steel into aluminum, use some anti-size.
Lets hope your solution works.
Definitely a live and learn ordeal, Richard. This time I took the time to clean the bolts up good. Good advice.
I'm feeling pretty good about it. I'm giving it plenty of time to set and cure before I button it up, add liquids and give her a go.
/ 425 front cover gasket blown #16
Just had a thought, the bolt that goes against the pump housing should have a lock nut otherwise it will work loose. If there is no room for a lock nut, then use a thread locker and flow the directions on the bottle.
Richard
I put red loctite on both nuts. Do you think it would still work loose?
