Will this tractor move building?
/ Will this tractor move building? #1
robbyr
Elite Member
western east central texas
ford and mahindra
We have a 14 x 32 metal building we're thinking bout moving from back yard to side yard. The tractor is a Mahindra 5570 70hp. The building has four 4 x 6 skids under it. Building is full of "stuff" such as tools and saddles. Wondering if I can drag it slowly with tractor? 0F5C3365-EC77-4D08-9912-8B7E44DD5A2B.jpeg
/ Will this tractor move building? #2
I moved a similar building on skids with a MF 135 once, it was a load for it.
I don't think you'll have any issues especially with some ballast in the FEL.
/ Will this tractor move building? #3
The tractor shouldnt be a issue but the strength of the building might. Adding extra weight to the floor and pulling at 1 point could damage the building. I see a tractor in the background that might help. Maybe add a pickup?
Good luck Pics too
/ Will this tractor move building? #4
Pulleys and cables can greatly increase the actual pulling force...it will basically come down to traction...
/ Will this tractor move building? #5
Yep it will move it
/ Will this tractor move building? #6
Can you put the tractor inside, support some with the FEL and support some with the 3pt using framework to trusses?
/ Will this tractor move building? #7
There is no doubt in my mind that the tractor will pull that building, especially if the tractor is ballasted. If the building is built strong enough and designed (chamfered skids) to be pulled. Might not hurt to spray some water in front of the skids to possibly reduce friction.
/ Will this tractor move building? #8
Don't pull with a V hook up. Put a spreader bar in, then do the V hookup.
/ Will this tractor move building? #9
It might be better in the long run though, if you took the time to empty out some of the heavier items first.
/ Will this tractor move building? #10
That seems like common sense.
/ Will this tractor move building? #12
I am going to assume the reason for doing this is so that the pull on the skids will be more straight in line with each one instead of putting inward pressure on the flooring materials to hold the skids apart. Your spreader bar would take the compressive forces instead of the flooring material. Is that what you had in mind?
/ Will this tractor move building? #13
You could put pipes under it to make it easier to move....
/ Will this tractor move building? #14
Yes that is what I had in mind.
/ Will this tractor move building? #15
Just speculating, but my hunch is dat building was built to sit right where it is, and not built to join de oil field shack club.
Channces are you never tok a up close look at a shack. Big difference in skids and how much bracing a shack has against shed you have. Bracing comes to mind real quick. Shack pretty much be sided up wid 3/4 plywood for bracing more den wind resistance. You got a tin can.
/ Will this tractor move building? #18
You’ll need a spreader bar on the tow chains or you’ll pull the skids together but that size tractor should make easy work of pulling the building.
/ Will this tractor move building? #19
Pulling it in a straight line may be ok, but turning it (if needed) could be an issue.
/ Will this tractor move building? #20
I moved a 12x24 with Jeep and winch, but I emptied it first.
If it's old, or strength is suspect, I'd play it safe and unload
the majority of it first.
