Alternative to Lock-N-Lube.
/ Alternative to Lock-N-Lube. #3
First pic looks like a LNL while the others are different. Which is it? The jaws look like formed sheet metal.?
/ Alternative to Lock-N-Lube. #4
I ran across one in our local farm supply store. I don’t have a lock and lube so can’t compare.
It works fine.
/ Alternative to Lock-N-Lube. #6
I ordered one. It won't get here until the first week of December. What's that all about?
/ Alternative to Lock-N-Lube. #7
"first week of December"??
Direct ship from China?
/ Alternative to Lock-N-Lube. #8
I've had them all and nothing beats the Lock-N-Lube. It kills me to pay retail but it's the only one I have found that works. On my deep recessed fittings on my Woods mower deck, I use the Lock-N-Lube extra long version and that saves me a lot of grief when greasing things. Just my two cents.
/ Alternative to Lock-N-Lube. #9
So..oooo correct !!
/ Alternative to Lock-N-Lube. #10
there is an alternative that 4shorts has advertised on his channel. it is similar in function to a quick connect chuck on an air hose but once you pressurize it you cannot get it to release. example if a zerk doesn't take the grease.
they also make a valve that you can add that releases the pressure when it does happen. it is by univerco out of quebec. lifetime warranty. not made in USA but atleast it is designed in north america. not sure exactly where it is actually made.
/ Alternative to Lock-N-Lube. #11
i dont have one but I do have a lock and lube and I would definitely recommend trying the lock and lube 30$ before investing in a battery operated grease gun 300$.
/ Alternative to Lock-N-Lube. #12
Exactly the process I went through, now using the L-N-L longer version for everything.
Also my needle adapter fits into the L-N-L fine.
KC
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2017 Chevrolet Express 3500 12FT Box Truck w/ Liftgate (A61573)
2017 Chevrolet...
2013 Bobcat T190 (A64126)
2013 Bobcat T190...
