Alternative to Lock-N-Lube.
   / Alternative to Lock-N-Lube. #2
   / Alternative to Lock-N-Lube. #3
First pic looks like a LNL while the others are different. Which is it? The jaws look like formed sheet metal.?
   / Alternative to Lock-N-Lube. #4
I ran across one in our local farm supply store. I don’t have a lock and lube so can’t compare.
It works fine.
   / Alternative to Lock-N-Lube. #6
I ordered one. It won't get here until the first week of December. What's that all about?
   / Alternative to Lock-N-Lube. #7
"first week of December"??
Direct ship from China?
   / Alternative to Lock-N-Lube. #8
I've had them all and nothing beats the Lock-N-Lube. It kills me to pay retail but it's the only one I have found that works. On my deep recessed fittings on my Woods mower deck, I use the Lock-N-Lube extra long version and that saves me a lot of grief when greasing things. Just my two cents.
   / Alternative to Lock-N-Lube. #9
So..oooo correct !!
   / Alternative to Lock-N-Lube. #10
there is an alternative that 4shorts has advertised on his channel. it is similar in function to a quick connect chuck on an air hose but once you pressurize it you cannot get it to release. example if a zerk doesn't take the grease.
they also make a valve that you can add that releases the pressure when it does happen. it is by univerco out of quebec. lifetime warranty. not made in USA but atleast it is designed in north america. not sure exactly where it is actually made.
Case 2090 Cab Tractor with Loader (A55218)
Case 2090 Cab...
2007 Hannay reels Hose Reel (A54865)
2007 Hannay reels...
Powder River Squeeze Chute (A55218)
Powder River...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
Electric Mobility Scooter (A54815)
Electric Mobility...
