47" Snowblower Rebuild
/ 47" Snowblower Rebuild #1
BCWoodtick
British Columbia
JD425GT, B2650HST
Good morning, I'm going to be starting to rebuild my 47" snowblower for the John Deere 425. Unfortunately it has been in pieces for a couple years now and am looking for a good schematic on how to put it back together? Also I will be ordering some beer bearings for it and want to make sure that the 47 snowblower parts will be the same as mine? Any help is appreciated.
Thanks
Ok, that was one of the places I've been looking, just wanted to make sure mine is the same as it's probably a '96-98?
When I took it all apart I didn't take any pictures?? Is there anything on the inside behind the fan or just the carriage bolts? I'm in the process of replacing that portion of the steal and don't think I'll get the square homes in?
Thanks
/ 47" Snowblower Rebuild #4
"square homes in" ??
Haha, please forgive my typo's...
The square carriage bolt holes on the housing behind the fan. I will have them drilled and might have to try and Dremel the squares in after? I'm assuming that I need to use the carriage bolts to keep the fan as tight to the housing as I can?
/ 47" Snowblower Rebuild #6
Is the serial number and model number label gone? If you have this info and match up with the serial number breaks in the parts schematic, you will get the right parts. If unsure, hopefully your Deere dealer has a good parts guy/gal to guide you.
I will have to have a look. Currently at a friend's shop installing new steal behind fan as it was extremely stressed out.
If anyone can confirm what year this serial number is for my 47 snowblower - M01471X081666
Thanks again
/ 47" Snowblower Rebuild #9
Posting on the internet is one of the things you can do after drinking several beers !
Good luck finding "beer Bearings"
Richard
/ 47" Snowblower Rebuild #10
Thanks again
Looks like 1989
Info found at the link posted above...
/ 47" Snowblower Rebuild #11
I think you must look at the throttle and cable area.
Looks like most of the parts are standard so I'm just trying to confirm from back of fan to sprocket orientation? The first pressed flange will have the raised portion in the hole of housing then bearing then next flange then locking collar? The old hole in housing is so distorted that I'm trying to figure out size of hole to drill? I'm assuming it's the outer diameter of the raised portion of the pressed flange?
Thanks
This is a picture of distressed portion and why I'm replacing that steal.
/ 47" Snowblower Rebuild #14
I just purchased a used 47" and found this, hope it helps
  • jOHN DEERE 47 SNOWBLOWER SERIAL NUMBER.pdf
Ya I'm hoping once I get it going again I'll get another 15 years out of it? I will try and be a little less abusive with it and should be able to as have a bigger Kubota to do the heavier snow work in winter now.
/ 47" Snowblower Rebuild #17
47 “ j d blower serial mo47sbx060919. Look at part auc16953 conversion. Good one
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2022 EZ-GO ELITE...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
