47" Snowblower Rebuild
   / 47" Snowblower Rebuild #1
BCWoodtick
British Columbia
JD425GT, B2650HST
Good morning, I'm going to be starting to rebuild my 47" snowblower for the John Deere 425. Unfortunately it has been in pieces for a couple years now and am looking for a good schematic on how to put it back together? Also I will be ordering some beer bearings for it and want to make sure that the 47 snowblower parts will be the same as mine? Any help is appreciated.
Thanks
Ok, that was one of the places I've been looking, just wanted to make sure mine is the same as it's probably a '96-98?
When I took it all apart I didn't take any pictures?? Is there anything on the inside behind the fan or just the carriage bolts? I'm in the process of replacing that portion of the steal and don't think I'll get the square homes in?
Thanks
   / 47" Snowblower Rebuild #4
"square homes in" ??
Haha, please forgive my typo's...
The square carriage bolt holes on the housing behind the fan. I will have them drilled and might have to try and Dremel the squares in after? I'm assuming that I need to use the carriage bolts to keep the fan as tight to the housing as I can?
   / 47" Snowblower Rebuild #6
Is the serial number and model number label gone? If you have this info and match up with the serial number breaks in the parts schematic, you will get the right parts. If unsure, hopefully your Deere dealer has a good parts guy/gal to guide you.
I will have to have a look. Currently at a friend's shop installing new steal behind fan as it was extremely stressed out.
If anyone can confirm what year this serial number is for my 47 snowblower - M01471X081666
Thanks again
   / 47" Snowblower Rebuild #9
Posting on the internet is one of the things you can do after drinking several beers !
Good luck finding "beer Bearings"
Richard
   / 47" Snowblower Rebuild #10
Thanks again
Looks like 1989
Info found at the link posted above...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A51573)
New/Unused 4ft...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
