47" Snowblower Rebuild
/ 47" Snowblower Rebuild #1
BCWoodtick
British Columbia
JD425GT, B2650HST
Good morning, I'm going to be starting to rebuild my 47" snowblower for the John Deere 425. Unfortunately it has been in pieces for a couple years now and am looking for a good schematic on how to put it back together? Also I will be ordering some beer bearings for it and want to make sure that the 47 snowblower parts will be the same as mine? Any help is appreciated.
Thanks
Ok, that was one of the places I've been looking, just wanted to make sure mine is the same as it's probably a '96-98?
When I took it all apart I didn't take any pictures?? Is there anything on the inside behind the fan or just the carriage bolts? I'm in the process of replacing that portion of the steal and don't think I'll get the square homes in?
Thanks
/ 47" Snowblower Rebuild #4
"square homes in" ??
Haha, please forgive my typo's...
The square carriage bolt holes on the housing behind the fan. I will have them drilled and might have to try and Dremel the squares in after? I'm assuming that I need to use the carriage bolts to keep the fan as tight to the housing as I can?
/ 47" Snowblower Rebuild #6
Is the serial number and model number label gone? If you have this info and match up with the serial number breaks in the parts schematic, you will get the right parts. If unsure, hopefully your Deere dealer has a good parts guy/gal to guide you.
I will have to have a look. Currently at a friend's shop installing new steal behind fan as it was extremely stressed out.
If anyone can confirm what year this serial number is for my 47 snowblower - M01471X081666
Thanks again
/ 47" Snowblower Rebuild #9
Posting on the internet is one of the things you can do after drinking several beers !
Good luck finding "beer Bearings"
Richard
/ 47" Snowblower Rebuild #10
Thanks again
Looks like 1989
Info found at the link posted above...
/ 47" Snowblower Rebuild #11
I think you must look at the throttle and cable area.
Looks like most of the parts are standard so I'm just trying to confirm from back of fan to sprocket orientation? The first pressed flange will have the raised portion in the hole of housing then bearing then next flange then locking collar? The old hole in housing is so distorted that I'm trying to figure out size of hole to drill? I'm assuming it's the outer diameter of the raised portion of the pressed flange?
Thanks
This is a picture of distressed portion and why I'm replacing that steal.
/ 47" Snowblower Rebuild #14
I just purchased a used 47" and found this, hope it helps
  • jOHN DEERE 47 SNOWBLOWER SERIAL NUMBER.pdf
Ya I'm hoping once I get it going again I'll get another 15 years out of it? I will try and be a little less abusive with it and should be able to as have a bigger Kubota to do the heavier snow work in winter now.
/ 47" Snowblower Rebuild #17
47 “ j d blower serial mo47sbx060919. Look at part auc16953 conversion. Good one
2006 BOBCAT 5600 TOOLCAT UTILITY WORK MACHINE (A63276)
2006 BOBCAT 5600...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
Gannon 12in. Bucket with Teeth Excavator Attachment (A64194)
Gannon 12in...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
