YM 146
/ YM 146 #1
bigweights
Member
john deere 4044m
Does anyone know how to turn up the injection pump on a yanmar ym146 with 2 cyl?
/ YM 146 #2
There is a YM142/YM146 parts manual out there.
And the member, thepumpguysc would know so much more about our fuel injection pumps too. There are components to swap to improve the flow.
/ YM 146 #3
Not sure if I been seeing pumpguync around much lately.?
Think I'd keep my fingers out of the pump. Not sure what extra you're going to get out of it anyway.
/ YM 146 #4
Out of interest, why do you want to "turn up" the injector pump?
/ YM 146 #5
/ YM 146 #6
My YM2610 engine, 3T80 is used on a few machines. The Hp is different due to the injector arrangement. Yes, the engine can do more Hp if the injectors were upgraded. Likewise, the 3T84 series, the most widely used YM engines are the same way.
As for pumpguync or pumpguysc, can't recall, he's been around recently on the other tractor forums. Dropping a PM usually works.
The injector pump upgrade will only raise to Hp a tad. More on the lower model machines vs. the higher model numbered machines. Because the higher models are just that, they are already at the peak injector pump settings. Thus, like Aaron mentioned, the IHI turbo that Rock2610 did would be the ideal way to go.
/ YM 146
Does anyone know the lug pattern on the ym 146 front and rear wheels?
/ YM 146 #8
Does anyone know the lug pattern on the YM146 front and rear wheels?
That is a very good question for the YM146 SCUT. The wheels are in the lawn tractor sizes.
/ YM 146 #9
Really late to this question but I also was messing around with mine and found the bolt on the front of the injection pump. You need to remove the cap and loosen the lock nut then the threads back out.
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2017 FREIGHTLINER M2 TRASH TRUCK (A67714)
2017 FREIGHTLINER...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2023 Dodge Durango AWD SUV (A66738)
2023 Dodge Durango...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
