Snow痴 coming
   / Snow痴 coming #22
I'll second that!:thumbsup:
I'll give it a 3rd thumbs up. :thumbsup::thumbsup::thumbsup:
Very impressive indeed. I toyed with doing the same thing last year and ended up getting an inverted snowblower instead. I kept the old rear facing blower too, since there are some things that need to have the blower enter the snow before the tractor. Maybe some day I will get enough motivation to do the same thing. Hope you don't mind if I copy your design. I like it.
   / Snow痴 coming #23
Couldn't readily get into my truck yesterday morning. FROST on the pumpkin.
Everyones pressure washers and hoses SAFE?
   / Snow痴 coming #24
First snow of the season in NW Montana. Gotta use front bucket/rear blade carefully until ground is frozen, THEN the MK Martin inverted blower will be the weapon of choice.
   / Snow痴 coming #26
   / Snow痴 coming #27
We got a couple of inches of snow yesterday, but it was so warm, it was gone by the time I got home last night.
If you put Edge Tamers on your bucket's cutting edge, you won't have as much problem with pushing snow over soft ground. Won't help with tires rutting things up, but that's another subject.
   / Snow痴 coming
Just getting little teasers of snow. Making progress, finalizing the details and bits to complete this project. Had to weld the top brace from the top link mount to the chain case while in position on the tractor. Did a lot of searching the net for hazards to the ECU while welding. Good ground, did not disconnect anything, welded away. Relief came when the tractor started after the weld. Will grab a couple of pics tomorrow. Had a warpage issue with the blower mounts after I put a couple of gussets in. Had to pull with a jack-all, cut a gusset and weld the expanded cut.
   / Snow痴 coming #30
Can't wait to see the progress and then the blower in use.
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
