Post puller
/ Post puller #1
ehcrain
Dinwiddie VA
kubota l3901 and massey ferguson 50
Who has a fel post puller? Ive got a L3901 and keep running into situations where I think one might work but want some real world feedback before pulling the trigger.
/ Post puller #2
I have pulled a few posts using a chain and an L3901. Be very aware of adding enough ballast to the rear of your tractor. I don't have any recommendations on specific pullers.
/ Post puller #5
I have used a strap and a chain both on various types of post with good results. The selection process of strap vs chain is typically based on the type of post/lack of damage wanting to do to the post.
Several factors to consider:
1) rear ballast is extremely important as the resistance of the post will want to pull the rear tires off the ground. Also if pulling from a corner of the loader is the tipping factor!
2) while T-post are fairly easy to straighten, it is relatively easy to break round, square, and wood post. The simple fact of raising the loaded changes angles and the pressure of the post creating bend on metal post and breaking on wood post. This is often at ground level, but can result in pieces above ground level which is likely to be unacceptable and create additional work.
3) concrete set post make all of the above more likely to occur.
On chain or strap wrap your post/chain in a manner that you pull from the bottom of the wraps and as pulled it tightens on the post. Wrap several times and low enough that the length of strap or chain allows the bucket/forks/whatever to begin the lift just above the top of the post. The bucket against the post increase the risk of bending/breaking.
/ Post puller #6
I sold it with one of my tractors but I had this tee post puller . Of course mounts on FEL . It was made by Speeco , this was over ten years ago . It has a rope tied to it to release the tee post were you want to drop it .
/ Post puller
Im thinking more in line with a hydraulic grapple style. Think danser intimidator.
/ Post puller #11
Built this one. As Don said, gotta be gentle on the bite with small stuff.
/ Post puller #12
B2650, your larger tractor will work fine, posts don't have roots. I max out at 3-4" tree trunks depending on tree species and soil conditions.
/ Post puller #13
I guess I have been doing it the hard way pulling t-posts. I have been using a chain wrapped around the t-post and then to the rear 3pt, and using the 1850lbs lifting power of the rear hydraulics. Pulls the first 12 inches out really easy, which is enough to pull rest of the way by hand.
/ Post puller #14
/ Post puller #16
Interesting video of post puller in action:
/ Post puller #17
I have a danuser intimidator. It works well (within the limits of what my tractor can do), but it's heavy - and depending on the rear ballast used (e.g. finish mowers or other implement that hangs far off the back of the tractor) can cause the tractor to start rocking fore-aft like a teeter-totter after hitting a bump (or operator-induced oscillations fore-aft). Which likely indicates it's probably at the heavy end of what I should be using with my loader (if at all).
Best technique I've found is what I read (somewhere) where you approach the post/tree/etc. grab it, lift slightly (just enough to load the front wheels) and drive either forward or back to loosen the post/tree, before lifting fully. ..... basically the same technique as removing posts/trees by hand (rock it a bit, and then lift it out). The thing to watch for is to make sure the tree/post is close to centered before closing on it as otherwise the closing of the jaws will put a sideload on the tractor's loader arms. I've managed to avoid doing damage so far, but make a conscious effort to center the object before grabbing it.
Have been tempted to try putting it on an adapter on the 3-pt hitch and see how well (or not) it works there, but haven't gotten around to it yet.
Overall, it's a handy tool as a grapple/post puller, but that specific implement likely needs something more than a compact tractor to fully leverage the implement's capabilities (using it as a stump bucket on a compact tractor generally hasn't worked that well). .... having said that if I had to do it over I'd still buy it given my uses and future plans (which will likely/hopefully include a larger machine at some point).
So proper ballast (heavy and preferably not hanging far off the back of the tractor), and grabbing as close to the ground as possible is definitely advisable as are the other suggestions/guidance that's been provided so far ....
...just my :2cents: ...(which is hopefully coherent as I'm still in the process of waking up)
/ Post puller #18
I use a 6 foot 3/8 chain. A sling works too.
/ Post puller #19
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
IRanch High-End Tricycle (A64119)
IRanch High-End...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
2024 CATERPILLAR 265 SKID STEER (A65056)
2024 CATERPILLAR...
1988 GREAT DANE FLATBED (A67714)
1988 GREAT DANE...
JOHN DEERE 325G SKIDSTEER (A67714)
JOHN DEERE 325G...
