Road Maintenance
/ Road Maintenance #1
albert
middle Tn
Toolcat D
I'm working with a 5600 Toolcat and have 1/2 mile of dirt/small rock road (with a lot of elevation changes) to maintain. Looking for suggestions/advice as to the best implement to get the job done. I need to re-grade 4-8 times a year depending upon rainfall. I'm currently using a pull-behind DR grader which gets the job done but it takes a while, requires many passes, and has no mechanism for crowning or sloping the road.
/ Road Maintenance #2
I did my 1000 foot driveway on the weekend. Tired of the many passes, mostly because I can't stand a windrow of any kind, I tried a new approach.
Pulled Harley Rake with S tines slightly engaged to stir up some material, followed by an upside down chain harrow behind the Harley.
Then dragged a ten foot length of light chain link fence behind my E-Gator which was quick, fun and easy to make everything picture perfect.
EDIT. For what it's worth. Any powered implement (like a Harley) will reduce your passes by many times. Think of it as an Electric Planer VS a hand one.
/ Road Maintenance #3
Im using the grader attachment, it will tilt to crown and once done pull a harrow upside down over it with the side by side
/ Road Maintenance #4
Will cost $$$'s but rake with drop down grader blade...2for 1.
/ Road Maintenance #5
If that's the toolcat with the 3pt on the back, one of those "land plane's" is hard to beat. And 4-8 times a year, you'll love it.
/ Road Maintenance #6
Land Plane
/ Road Maintenance #7
Rear Blade with a Guide Wheel
/ Road Maintenance #8
Pull Behind Grader (old or new)
/ Road Maintenance #9
Road Maintainer
/ Road Maintenance #10
I like that, BUT to work right, it would have to be the exact width of your road.
And how does it behave when it encounters larger stones? Product videos always show stuff being used under ideal conditions for the machine in question.
/ Road Maintenance #11
The OP said he had a 5600 which has no 3pt but it does have a hitch/drawbar.
/ Road Maintenance #12
I built this.
/ Road Maintenance #13
Your 3 pt arms are your crowning mechanism!
Just shorten one arm with the screw mechanism and there U go!
And, YES, the DIY drag is most effective.
3 blades works just great.
Let the last blade push over run towards the road center and U will create your crown.
Nobody sells a drag as shipping would be horrendous.
For sure it is a DIY project for anybody that owns a welder.
/ Road Maintenance #14
I'm sure he would if he could! He has the 5600 that has NO 3pt. but has a dump box. I have the 5610 that does have the 3pt but no dump box.
/ Road Maintenance #16
This will also work on a 3 point box blade: https://www.tractorbynet.com/forums/attachments/251362-skidsteer-box-scraper.html
/ Road Maintenance #17
/ Road Maintenance #18
Yep, neat:
/ Road Maintenance #19
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2025 SZYMJ Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 SZYMJ...
2018 Volkswagen Tiguan SUV (A64557)
2018 Volkswagen...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
