Well pressure tank oddity
/ Well pressure tank oddity #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
Our tank has a 40/60 switch and a few years ago I recall verifying those pressures on the gauge. I happened to notice the other day that pressure is dropping to 35psi then being pumped back up to 65psi. So something is off. Could this be a sign of a leaking bladder, or maybe the switch is going bad? The switch clicks on and off like usual. I don't detect any oddness other than the change in pressure.
Also, tank and switch are about 7.5 years old.
/ Well pressure tank oddity #3
My first thought was a ruptured bladder. I just go with an old style tank and fill it once a year.
/ Well pressure tank oddity #4
Because your low pressure is lower and your high pressure is higher, I don't think it is your tank.
Pressure switches do wear out over time, but two things to try;
1) try adjusting the upper and lower court off/cut in via the adjustment screws/nuts. Sometimes they do slip with time.
2) if #1 doesn't, work, try cleaning out the pipe to the pressure switch. They often get corroded up with scale, rust, and/or sand.
If that doesn't fix it, I would replace the switch. Generally, they are inexpensive. FWIW: I have hard water and replace them about every six years or so. YMMV...
All the best,
Peter
/ Well pressure tank oddity #5
I had odd water pressure issues a couple years ago. It was due to the small pipe leading to the pressure switch being clogged. I cleaned that, put on a new switch and issue solved. I'm curious how long it's going to last before it starts showing signs again. Just something to check if you decide to replace the switch.
/ Well pressure tank oddity #6
You should be able to adjust your pressure switch, plenty of youtube videos, if it wont adjust, replace switch. Before I would do anything, I would make sure the pressure gauge is valid. They are not that expensive at the big box stores.
Start cheap and work your way up.:laughing:
/ Well pressure tank oddity #7
I had the same problem, but I replaced the rust-clogged 1/4 inch iron pipe with brass.
Bruce
/ Well pressure tank oddity #8
All the best,
Peter
*2 first and always. Simplest, quickest and most likely. I have to do mine about every 5 years. Probably not needed but I put in a new pressure switch at the same time, the cost is surprisingly low.
/ Well pressure tank oddity #9
You don't say what type of well etc...if there is a foot valve or a check valve on the suction side it could possibly be leaking the pressure down...if there is a cut off valve on that line try cutting it off and see...
/ Well pressure tank oddity #10
Just thought I might add this. I have been meaning to add a second pressure switch with a higher LOW cutout, as I find my water softener doesn't work reliably at the lower limits of my current switch. So switch to the higher one for the softener, then switch back.
/ Well pressure tank oddity #11
Whether it's brass or steel, that 1/4" pipe will clog with scale or rust. I find the brass easy to clear out, and usually add a new switch at the same time as mentioned above. I used to mess with switch adjustments but realized it was a wasted effort and easier to swap out for a new one when they are off by more than a couple pounds.
My dad's pump had a 30-50 switch that gradually moved to 25-60. That's a wide pressure range, and adds stress to the water heater and expansion bladder through the many cycles. Both switch and pipe were less than 10 years old but easy to change out. I cleaned the pipe (it was plugged 50%) and added a new 40-60 switch and it's been working smooth for a year.
/ Well pressure tank oddity #12
If its a check valve leaking put an ear to the pipe after the pump kicks off and you will hear the water running back into the well.
So I put my cell phone camera next to the gauge and filmed it after I turned on an outside faucet. Made it easier to see the numbers since the gauge is right near the floor and hard to read by eye.
Pressure dropped to 35 psi before the switch kicked on, then pressure went up to about 62 psi before the switch kicked off. After it kicked off, the gauge needle bounced to 65 psi (probably expected) then settled at 61-62 psi.
I think the high pressure cutoff is probably working OK, as 61-62 psi is pretty darn close to where it needs to be. The low end limit at 35psi is low though.
We do have hard water, so it wouldn't surprise me if that 1/4"pipe has a lot of crud in it after 7.5 years. I would have never thought of that but it's a prime suspect now. I think I will order a new switch to have on hand and then try to clean out that pipe.
Thanks for the input guys, I appreciate it!
/ Well pressure tank oddity #15
Hard water is hard on everything. Possible calcification of the rubber pressure switch doohicky.
/ Well pressure tank oddity #16
The pressure switch won't have anything to do with the tank losing pressure.
Tank is not losing pressure, it holds steady no matter where it's at. In the original post I meant to imply that the 40/60 switch is letting pressure go down to 35 psi before it kicks on. So the pressure is dropping lower than the limit of the switch.
/ Well pressure tank oddity #18
Depending on how cheap you are, you could take apart the switch and clean it up. The diaphram that is. Kind of satisfying work.
Sadly, it seems that every pressure switch is of poorer quality then the one it replaced, so cleaning one up (with vinegar) may not be a bad approach. When you mentioned hard water, well, that probably sums it up.
/ Well pressure tank oddity #19
I would first verify the gauge is correct. You can make one that connects to hose bib. Most of those gauges are not accurate and do not last forever.
Then adjust per instructions on switch they do not last forever either and controlled by spring pressure.
If problem persists replace the switch. It could be clogged or just wore out
Although not your issue verify tank pressure as they should be checked every few years. Water power needs to be off and tank drained. Tank pressure should be 2 pounds below cut In pressure , preventative maintenance here.
/ Well pressure tank oddity #20
I bought my last switch at Ace Hardware. They had a good selection, quality, and decent prices. I was surprised.
