Transfer switch
   / Transfer switch #21
Me...I would shut off power to shed. Unscrew panel to the right of breaker box. Install a single outlet box about where white box is shown, fastened to a stud. Install an outlet socket. Whatever the gauge wire there now going up to door opener outlet (say it's 12/2) I'd get a length of 12/2. This goes of course hot, neutral, ground at outlet, other end wired in panel box, the hot (black) to breaker for ceiling breaker. This new outlet could still be used since it's protected by same breaker for opener.
When power is lost, flip the opener breaker off. Plug generator into new outlet. It will feed power up to ceiling breaker only. 20200927_195133.jpg
   / Transfer switch #22
When power is lost, flip the opener breaker off. Plug generator into new outlet. It will feed power up to ceiling breaker only.View attachment 671109
That would require a male-male death cord and could also allow the breaker to be turned to the on position when generator power is applied. This could back-feed the panel, or, conversely apply line power to the generator if power is restored. Neither situation is a good one.
Yes, it would work, but not a good idea.
   / Transfer switch #23
I should have added, this is not a residential door and opener. The door is 12 x 24. I tried to open it when the power was out, it's so heavy, no way anyone can open it manually. It is a steel insulated and only 6 years old with annual servicing.
I called the installer, asking about a battery backup but they don't make one for a commercial door like this one.
I like Diggin's idea of a hanging drop cord, cheap fast & easy. But I would prefer a more professional look to it......depending on the price. If it's $1000, forget it, if it is half of that then okay.
It looks like a typical garage door opener except you say the door is 12' x 24' and a garage door should be balanced with springs so it can be hand lifted by pulling on the trolley trip emergency rope?
You don't have an emergency trip rope to release the trolley?
I am a little confused, maybe you could provide a photo of the trolley attachment at the top of the door.
KC
   / Transfer switch #24
I agree...but all he's trying to do is power the opener. All you have to do is remember the steps and sequence.
For that matter I'd have instructions: "turn main AND opener breakers off", plug into outlet then generator.
Or you could install a recessed male outlet, then just an extension cord there to generator. Easy to buy or make a child-proof cover if you wanted.
   / Transfer switch #25
thats even worse. That outlet would be live when utility power is present. Very dangerous.
   / Transfer switch
   / Transfer switch #27
Gee, Moss...Where's your sense of adventure? :laughing:
Seriously I agree, it is a bad idea, but the solution is even simpler. Run the opener down to that outlet in the photo. When power goes out, unplug it and plug it into the extension cord from the genny. No it's not as pretty as the rest of the shop, so paint the cord off-white and it will disappear. Or use surface mount conduit (aka wiremold) to hide it.
   / Transfer switch #28
Yes, that is the simple solution, and what i'd do if it were my garage. In fact, that is the way my garage is now... the opener cord goes across the top of one of the ceiling joists, down the wall, and is plugged into an outlet above a workbench.
   / Transfer switch #29
What you described is, as far as i know, not against code. It's quite common to have multiple outlets on a single breaker. Generator transfer switches are required to be designed in a way that it is physically impossible to energize the (assumed down) grid. But there is no transfer switch here. Just two outlets on one breaker. Totally normal. Now, what you choose to do with that outlet, like feeding generator power into it with a dead man cord, I don't know where that falls on the spectrum of legality. I would officially advise against it. Unofficially, if you know enough to even think of performing the prescribed actions, then you probably know enough to not cause an issue. But your audience may not, and may be getting dangerous ideas.
This part however I'm afraid I must condemn both on and off the books:
   / Transfer switch #30
Here is a pic of the breaker box.
Just to make sure it isn't an easy job, it is surrounded by 2x4's and covered with metal.
This is one of the reasons why I asked about installation difficulty.
What do you think? Attack it or hire it out?
It's an easy job if you know what you are doing. Based on your questions you should be hiring an electrician. If you are worried about cost get 3 quotes and adjust your expectations.
Forklift (A56857)
Forklift (A56857)
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
