New garage time!
/ New garage time! #741
The vertical distance measured from the average elevation of the existing grade at the location of the building to the highest point of the roof for flat roofs, to the deckline of mansard roofs and to the mean height between eaves and ridge for gable, hip and gambrel roofs, provided that chimneys, spires, towers, mechanical penthouses, tanks and similar building architectural projections of the building not intended for human occupancy shall not be included in calculating the height. If there are two or more separate roofs on a single building, the height of such shall be calculated from the highest roof.
If these are your regs, a Gambrel would be your friend. I've attached a sketch of what that could look like. I know I didn't include the height of the bottom joist, but I also didn't include any overhang which would lower the eaves height in the calculation.
/ New garage time!
"The vertical distance measured from the average elevation of the existing grade at the location of the building to the highest point of the roof for flat roofs, to the deckline of mansard roofs and to the mean height between eaves and ridge for gable, hip and gambrel roofs, provided that chimneys, spires, towers, mechanical penthouses, tanks and similar building architectural projections of the building not intended for human occupancy shall not be included in calculating the height. If there are two or more separate roofs on a single building, the height of such shall be calculated from the highest roof."
That right there sounds like you could gain some height by having a steep roof pitch. It seems to say you measure half-way up the gable wall to determine the height. I'd take that and head to the building department for clarification. Written clarification!!
Good luck.
That is actually from the building department. In writing no less. So I go up 25' which leaves me with 1' but i don't really need to have a 1:12 roof, I can have a 2:12 roof because if hte bottom is 25' the top can be 27'. I don't want to be tall without usable space, I want as much usable space as possible, and to me that's squared space.
/ New garage time! #743
Going up to 25' gives you a tall second story. A gambrel roof gives you a useable 3rd story. I also think it would be a more attractive building.
/ New garage time! #744
Yep. Put a gambrel roof on it. Looks like a barn. Paint SEE ROCK CITY on the roof and CHEW MAIL POUCH TOBACCO on the side. Your neighbors will love it. ;)
2D911D0D-0136-4C84-940C-DC3579F9DC7C.jpeg EAD758B9-FEA6-4F4B-A033-DB59CAF7E4A2.jpeg
/ New garage time! #745
That is funny. There was a Rock City painted on a barn near Beardstown Illinois. The barn was falling down and they repainted the ad, then the barn fell down a short time later.
/ New garage time! #746
The paint must've been the straw that broke the camel's back. :D
/ New garage time! #749
And of course the painted messages should be above tree level on the proper side.
/ New garage time! #750
If the lower ends of the gambrel roof in airbiscuit's post were extended 24" lower on the sidewalls, would that allow fatjay to go another foot higher?
/ New garage time! #751
Jay, did you look at the link I posted? Your local code is exactly like what I was talking about. Your height measurement is to the MEAN, meaning Average or middle of the roof slope. So yes you can build a tall box with a low slope roof, OR use attic or gambrel trusses to gain a 3rd story and stay under your limit.
The other thing to make darn sure of, is to complete all your backfilling around the building as high as you feel comfortable with against your foundation. Your local inspector may well measure all around the building, so get that grade established as high as you can to make sure you don't fail.
/ New garage time! #752
I had a friend build a house in the winter. Inspection came and turned him down. He did not have sod or grass seed planted. Also the front porch was 1 inch over in height. He was told that he had to have a hand rail on the one step to his porch. His wife did not want it. He pushed about 6 inches of dirt up to his house. And thru out cheap grass seed. Inspector said that it looked bad and that the grass seed was not going to come up. Too little seed for area. My friend asked "Does it meet code?" It passed. He moved in and two weeks later leveled his yard. Spring came and he laid sod. Interesting what a load of dirt can do.
/ New garage time!
I'm reminded of something trump did. In one of his florida golf courses he put up a 50' flag pole. The code people came out and said maximum height of a flag pole is 20'. So he took it down, put up a 30' pile of dirt, then planted a 20' flag pole on top of that. And it was to code.
I'm still partial to the 12' ceiling and 2:12 roof, better than 1:12. I'm having it engineered so the trusses can take 1000lbs, then i'll have enough strength for an equipment lift on the trusses to lift from first to second floor.
In the mean while, I took down a fence that fenced off the back yard so machines could get in. Now I need to rebuild it. Instead of chain link I'm going to do something a little nicer. Some assembly required.
/ New garage time! #754
That's pretty funny... moral of the story... be careful what you ask for! Not saying you should intentionally pizz off your neighbor but you might find a solution that is to code that is worse for him. If you do, then you can maybe get a variance easier?
/ New garage time!
The goal isn't to piss off the neighbor, it's to get as much usable space as possible. The neighbor screwed me over and cost me a fortune, so i'm pretty pissed off at him. If he had been up front about it 6 months ago before all the headache, maybe I wouldn't have considered these changes. But when you fight for something for 6 months and finally get a chance to move forward, only to have the rug pulled out from under you, you stop caring about being the nice neighbor.
/ New garage time! #756
I hear you... been there done that with a neighbor at my previous residence in suburbia. I am now in semi rural area surrounded mostly retired folk, mid westerners, and folks that help each other out without having to ask. We are all motivated to help maintain our private drive and surroundings regardless of who's property we are on. Very blessed now.
/ New garage time!
This area used to be semi-rural, but times have changed and it's become very popular. Builders have moved in and built everything up. There used to be 2 grocery stores in the area, the nice one and the crappy one. Now there's over 10 in the same area. And the people to support it. But not the roads. Traffic went from a breeze to a nightmare. All in the course of about 15 years. Population has gone up 5 fold. And it's not slowed down due to covid, people rushing out of the city, making this the "new" city.
There was a new 12 home development on just over 2 acres, mini mansions about 3500 sq ft with no yard to speak of. A guy wanted to put in a back porch but the contractor couldn't get his machines between his house and his neighbors house. They put a run-off basin to collect the rain water because the houses were so close together. The basin overflows so the people in the development had to pay to dig it deeper. Just one of many **** shows that the elected officials keep allowing. No preservation of heritage. When I bought my house here, I bought it from someone who died, and left it as is. Not a new construction. I wouldn't buy one of these new constructions, the walls are so thin and the houses are so close together you get woken up by your neighbor taking a piss at 3am. I've rebuilt my home a few times to suit my needs and wants, and I'll not be driven out of it.
/ New garage time! #758
How many miles on the excursion looks like its in pretty good shape. mines got 450,000 and is a total rust bucket. Mines a 7.3 thank god.:drink:
/ New garage time! #759
That looks like my 93 Suburan a couple months ago when I brought home all of the framing for our 24x24 garage addition. Everything but the trusses and wall and roof sheathing in one load. Took the trailer for the sheathing and again for the shingles.
That fence will look much nicer than chain link.
/ New garage time!
Only 250k miles, with the 6.0. I love that truck, i've had it 15 years and have gone everywhere in it and done everything with it.
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
Landhonor Mini Excavator Ripper Tooth (A66285)
Landhonor Mini...
