Ford 1210 diesel
   / Ford 1210 diesel #1
Thommy
Ford 1210
Within 2 hours after the oil is changed,the tan colored new oil turns very dark ,almost black.
What causes this??
   / Ford 1210 diesel #2
Did you change the filter too? There's a lot of dirty oil in the filter.
How long has it been since the last change? Could be dirty sludge in the bottom of the oil pan.
   / Ford 1210 diesel
I always change the filter with the oil.
   / Ford 1210 diesel #4
What causes this??
Our old 1100 is the same way and has been since new. Don't know why.
   / Ford 1210 diesel #5
I suppose it is the old diesel engine technology. My 1700 does not burn any oil, very good compression and power, noting wrong with head gaskit, no mixing of anti-freeze and oil and yet after 5 to 6 hrs engine oil gets dark. Now, I use Rotella for engine oil and not NH brand and saying that never had any issues either. I also change and filter faster than I should at every 50 hrs. Conversely, I use kubota oil for my MX-4700 and at first 50 hr of service the oil looked pristine to the point I saved it in a gallon jug and just use it for my oiler thingy and oil up joints and stuff with. I think it is the oil but more so engine technology.
   / Ford 1210 diesel #6
Hi man I have a ford deiseal 1210 , I want to put a loader on mine , do you have any pictures of where the hoses are attached to ? I have the Manuel I can send you a copy of it . Where do I attaches the hoses , it is the hydraulic manifold block near the breaks ? Any picture would help thank you
   / Ford 1210 diesel #7
I don't know why the oil is black If you changed the oil it should be fine just change the filter , it should be fine
   / Ford 1210 diesel #9
hansan, I have a 1210 with a loader. I'll try to include pictures.
If you need more pictures, I can take any you might need.
Adams 5T HC Spreader (A55301)
Adams 5T HC...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2001 Ford F-250 Pickup Truck (A55852)
2001 Ford F-250...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
