Ford 1210 diesel
   / Ford 1210 diesel #1
Thommy
Ford 1210
Within 2 hours after the oil is changed,the tan colored new oil turns very dark ,almost black.
What causes this??
   / Ford 1210 diesel #2
Did you change the filter too? There's a lot of dirty oil in the filter.
How long has it been since the last change? Could be dirty sludge in the bottom of the oil pan.
   / Ford 1210 diesel
I always change the filter with the oil.
   / Ford 1210 diesel #4
What causes this??
Our old 1100 is the same way and has been since new. Don't know why.
   / Ford 1210 diesel #5
I suppose it is the old diesel engine technology. My 1700 does not burn any oil, very good compression and power, noting wrong with head gaskit, no mixing of anti-freeze and oil and yet after 5 to 6 hrs engine oil gets dark. Now, I use Rotella for engine oil and not NH brand and saying that never had any issues either. I also change and filter faster than I should at every 50 hrs. Conversely, I use kubota oil for my MX-4700 and at first 50 hr of service the oil looked pristine to the point I saved it in a gallon jug and just use it for my oiler thingy and oil up joints and stuff with. I think it is the oil but more so engine technology.
   / Ford 1210 diesel #6
Hi man I have a ford deiseal 1210 , I want to put a loader on mine , do you have any pictures of where the hoses are attached to ? I have the Manuel I can send you a copy of it . Where do I attaches the hoses , it is the hydraulic manifold block near the breaks ? Any picture would help thank you
   / Ford 1210 diesel #7
I don't know why the oil is black If you changed the oil it should be fine just change the filter , it should be fine
   / Ford 1210 diesel #9
hansan, I have a 1210 with a loader. I'll try to include pictures.
If you need more pictures, I can take any you might need.
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A48836)
2007 International...
2012 Ford Fusion SE Sedan (A48082)
2012 Ford Fusion...
5ft Feed Tub w/ Hay Rack (A49251)
5ft Feed Tub w/...
Ford 8N Tractor (A49251)
Ford 8N Tractor...
International 445 Small Square Baler (A49251)
International 445...
Knapheide Truck body, 6 Boxes (A47371)
Knapheide Truck...
