New garage time!
/ New garage time! #721
Appreciate the update. I've always thought trees next to a building was a mistake, so for the longevity of the building, and since you wont see them with your building in the way, it might be a good idea to remove them. I'm sure your neighbor will understand.
/ New garage time! #722
Are you limited in what type of roof you can install on your shop? Can you build a Gambrel Roof if they turn you down for the third floor and just call it attic space?
/ New garage time! #725
Great suggestion. I did that when I built my shed/cottage.
/ New garage time!
I'm just going to do a 1x12' roof with standing seem steel roofing and take the 8' walls up another 4' for a total of 12', which will let me do loft storage or a faux attic.
/ New garage time! #727
That's pretty clever. They wont know where the floor is from the outside.
Did you say you are going with a 1:12 pitch roof? WHY?
/ New garage time! #728
I think most places limit the total height of a structure.
Here's ours for outbuildings, for example. It's based on total height. And that can vary depending on lot size. And square footage depends on the house and total of all outbuildings. I could have more outbuildings square footage than my neighbor because my lot is listed as 1.01 acres and his is less than 1 acre. Weird stuff, but it's the law.
/ New garage time!
My height is restricted to 26', not 2 floors. My original plan was 35' and 3 floors, they restricted me to 26', which i was fighting against. first floor is 12' plus 1' floor which leaves me with 13' remaining. If i make the 2nd floor 12' it leaves me with 1' for a roof. With standing seam steel roof you can go down to a 1:12 pitch. My trusses will need to be 16" on center though to get the snow load rating according to my truss company.
/ New garage time!
Ours is 35' for zone 2, but because I needed that setback variance they threw on the additional restriction of 26', the 1' floor and 8' walls.
/ New garage time! #731
I never heard of any of those restrictions before, but that's probably because I live in Texas. Each city has their own code, but when you are outside of city limits, there is no code. You can have as many barns as you want, and they can be as big as you want. And in all honesty, most of the cities rarely deal with code on home remodels or additions. New construction keeps the Inspectors busy!!!
/ New garage time! #732
I live outside the city limits of South Bend, in the county, on a lot zoned residential. Those are county restrictions on residential lots. If you get AG zoning (like our rural property), there are much fewer restrictions.
/ New garage time! #733
Get as much of the usable space you can. Nice plan.
/ New garage time! #735
Jay, how does your township/city regulate and measure the actual building "height" though?
In my township of Michigan, we have maximum building heights. But they are measured to the mid-line of the roof! So halfway in height between your roof peak and your gutters is where they calculate the actual building height. This means that you can build a tall building with a flat roof, or a lower building with a peaky roof design. OR, a barn-like structure with a gambrel roof design, because the entire side of the top story is then "roof". I could easily build a 3 story in "26 feet" using a gambrel roof - since the peak could actually be ~30 feet. Cant find an exact diagram right now but this is similar:
https://www.ridgefieldct.org/sites/...loads/info_on_calculating_building_height.pdf
/ New garage time! #736
That’s worth exploring. Interesting idea.
/ New garage time! #737
Yeah, I was surprised to learn about it when building my house and pole barn; not that I pushed any height limits myself. But this kind of residential building height regulation is quite common across the country, as my google searching revealed. I suppose the reasons for it are myriad, but in particular, it helps establish a fair but somewhat flexible limit that accounts for the variety of roof structures. Seems like building and zoning officials don't exactly go out of their way to explain the complications of this rule, maybe because they don't want people pushing the limits.
So in essence, Jay, don't let them just tell you a number for max height! Find out exactly how they measure and regulate it.
/ New garage time!
The vertical distance measured from the average elevation of the existing grade at the location of the building to the highest point of the roof for flat roofs, to the deckline of mansard roofs and to the mean height between eaves and ridge for gable, hip and gambrel roofs, provided that chimneys, spires, towers, mechanical penthouses, tanks and similar building architectural projections of the building not intended for human occupancy shall not be included in calculating the height. If there are two or more separate roofs on a single building, the height of such shall be calculated from the highest roof.
This makes me a bit more confused. Anyone with building experience want to weigh in?
/ New garage time! #739
"The vertical distance measured from the average elevation of the existing grade at the location of the building to the highest point of the roof for flat roofs, to the deckline of mansard roofs and to the mean height between eaves and ridge for gable, hip and gambrel roofs, provided that chimneys, spires, towers, mechanical penthouses, tanks and similar building architectural projections of the building not intended for human occupancy shall not be included in calculating the height. If there are two or more separate roofs on a single building, the height of such shall be calculated from the highest roof."
That right there sounds like you could gain some height by having a steep roof pitch. It seems to say you measure half-way up the gable wall to determine the height. I'd take that and head to the building department for clarification. Written clarification!!
Good luck.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Trump 2028 Metal Sign (A65583)
Trump 2028 Metal...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
Cattle Feeder (A65640)
