Kubota hydraulic filter hook spanner wrench
   / Kubota hydraulic filter hook spanner wrench #1
Mat4644
Can't find where Kubota offers a spanner wrench that fits their hydraulic filters with notches. Found this one on Amazon. Anyone else using a hook spanner wrench?
Seems strange the filter base is designed with notches typically used with spanner wrenches and no wrench offered. Plus many report this is often a very difficult filter to remove.
   / Kubota hydraulic filter hook spanner wrench #5
I've always used a strap wrench. First time filter removal is often difficult on any tractor. They are tightened up uber-tight and usually painted over with the frame painting. On first time removal - run a box knife around the filter, at the base, and cut this paint bond between the filter and the frame.
   / Kubota hydraulic filter hook spanner wrench #6
If I'm not mistaken, those Kubota filters with the notches are meant to be pretty tight - tighter than the regular style. My cheap rubber strap wrench won't do it. A large pipe wrench works well if you're careful. Just put it on the reinforced ring right at the base.
   / Kubota hydraulic filter hook spanner wrench #7
Toss the cheesy rubber strap wrench and get a real one made from fabric. Using a pipe wrench to install a filter is nuts. Even a charge pressure filter.
   / Kubota hydraulic filter hook spanner wrench #8
This x2. It took feet planted on a 24” pipe wrench to get mine loose at first service.
   / Kubota hydraulic filter hook spanner wrench #9
It's a heavy metal base so I've used a screwdriver and a hammer on it. I believe that's the one that has the magnet. If the new one doesn't have it I would swap it over, after cleaning it up, from the old one.
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
