Kubota hydraulic filter hook spanner wrench
   / Kubota hydraulic filter hook spanner wrench #1
Mat4644
Platinum Member
Can't find where Kubota offers a spanner wrench that fits their hydraulic filters with notches. Found this one on Amazon. Anyone else using a hook spanner wrench?
Seems strange the filter base is designed with notches typically used with spanner wrenches and no wrench offered. Plus many report this is often a very difficult filter to remove.
   / Kubota hydraulic filter hook spanner wrench #5
I've always used a strap wrench. First time filter removal is often difficult on any tractor. They are tightened up uber-tight and usually painted over with the frame painting. On first time removal - run a box knife around the filter, at the base, and cut this paint bond between the filter and the frame.
   / Kubota hydraulic filter hook spanner wrench #6
If I'm not mistaken, those Kubota filters with the notches are meant to be pretty tight - tighter than the regular style. My cheap rubber strap wrench won't do it. A large pipe wrench works well if you're careful. Just put it on the reinforced ring right at the base.
   / Kubota hydraulic filter hook spanner wrench #7
Toss the cheesy rubber strap wrench and get a real one made from fabric. Using a pipe wrench to install a filter is nuts. Even a charge pressure filter.
   / Kubota hydraulic filter hook spanner wrench #8
This x2. It took feet planted on a 24” pipe wrench to get mine loose at first service.
   / Kubota hydraulic filter hook spanner wrench #9
It's a heavy metal base so I've used a screwdriver and a hammer on it. I believe that's the one that has the magnet. If the new one doesn't have it I would swap it over, after cleaning it up, from the old one.
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
NEW HOLLAND TC30 TRACTOR (A51406)
NEW HOLLAND TC30...
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
UNUSED FUTURE FT13CJ EXCAVATOR (A54756)
UNUSED FUTURE...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
